Perhaps the wiring has broken. Seen that before (wiring is too tight and snaps just near the sensor)
The knock sensor is a pita to get to, and the coaxial from the sensor is incorporated into the loom for the injectors. I should have a spare for that somewhere too if you want to change them both.
Have you checked the ecu plug inst loose or corroded?
Thanks for the responses.
Symptoms. Runs OK. Significantly down on power, comes on to boost later and not as strongly. Uses about 3L per 100km more with gently driving. Runs even more ridiculously rich while warming up.
I assume is running rich and retarded. (Who does that describe?)
Mechanic had analyser attached and it showed knock sensor faulty. I asked if it could read same if just a problem with the connector. He said the software could distinguish between faulty sensor and faulty connection.
I was quite suprised that the stagea was in his device. That said, he tells me he paid a few grand for the last SW upgrade to it alone.
Will double check connections on the week end but he isn't known for BS when not sure what is going on. Sounds like I might get him to put it in so he can do the swearing and loose skin but will have a look at where it is first.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
