hey guys just a quick question...
have this noise coming from my cam cover.
when its cold sounds a lil loud with revs around 1200/1300 rpm.
when i rev it goes away after 1600rpm and when idling at around 900/1000 can just hear it a little bit.
as it warms up it goes away at normal temp and goes away...
heres a video of it similar to mine or almost identical to be honest at the last 25 secs of video.
100% from the cam cover as i rember month ago tigtning those allen key bolts there and got extremly loud then loosend them and went away but its back again.
any ideas would be great or help on this as a few people have had this problem after reserching it but all different opinions...
Edited by R33ram
https://www.sau.com.au/forums/topic/404972-noise-from-cam-cover/
Yea mine has been making this noise ever since the timing belt was done but i had a entire kit installed bearings belt everything changed professionally now it makes this noise on a cold start and goes away once it's warmed up...
What's the worst case scenario is it something that should be fixed asap or??
Edited by Lethal_aussie
yours sounds like idler, if you are worried get the belt tension checked it could be too tight, if you installed a GATES belt and had it tension to stock spec it could be over tight.. worse case the idler gives way...
yea get it checked tommorow but hate taking it to mechanics as they are always like what noise lol
Is there any damage to be done or is it just a noise that gets annoying and no affect to engine besides that?
I did put a bit of wd40 or it got in there and became louder lol so most likley the cause is what you saying....
Yep was a gate's racing belt kit, if the idler gives away what will happen lol? Just not crank over or will it actually damage the engine on failure? If its just a noise i wont worry about it ... Was all done professionally so its all under warranty etc ill just blast the mechanic and they can cop the bill.
Besides the noise it does on idle on a cold start ... would it get much worse before that would happen or would it just suddenly happen? I had the entire gates kit done doesn't that include new idler's etc?? paid 400 bucks be damned if it was just the belt they replaced... regardless mechanic would be at fault anyways since they installed the kit and did the timing etc??
Did you supply the mechanic the parts or did they suggest the parts and source the parts? Warranty might not stand if you supplied the parts...
I installed the kit myself did the tension up and it was sweet, no noise or anything for a good year, recently i had to take the belt of and when i started the car it made that exact noise but much louder, i loosened the tensioner off and the noise has gone, im not worried that the belt will slip or jump and it was a Cu*t to even get off and back on again.
Next time i will just buy genuine Nissan belt as their is nothing is wrong with them..
Yea im thinking that to should of got nissan ... im thinking its kinda overkill for street use gates... yea they sourced and recommended the gates timing belt kit they go through justjap i think.. as it was stronger etc
I always pay for a professional to install and source everything as im mechanically stupid in most area's lol... short of a oil change etc
  • 4 weeks later...
*Just a update* on this guys, Had it checked again and the noise was the Timing belt which was actually loose.. and needed to be re-tensioned so all good now, cheer's :)
Hmmm
That is odd, how can the belt be loose?
I have exactly the same noise as you had, belt done months ago ..
Apparently the original mechanic that worked on my car was meant to re-tension the belt when i had the gates kit installed to begin with and didn't... The main mechanic "owner" said he had to redo the kit and tighten it as it was loose which is what was making the noise..
This is what i was told..
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
