R35 Parts for Sale
Snowman
 Share
Hi Guys,
Ok I've got some used spare parts and I'm prepared to let them go pretty cheap to free up some space in the garage.
2010 OEM 20 inch wheels with 50% used Dunlop's - $3,000 (There are a few scratches on two of the wheels. Easily fixed if repainted though)
Full exhaust - $2,500
80 mm straight through dump pipes
100 mm twin resonated midpipe
90 mm Rear section Inc two mufflers
This is the full exhaust that I ran on the car at Bathurst last November. Its not going to save you as much weight as a titanium system would but its still much lighter than stock and It's super quiet for daily driving but when you get the power down it comes on song very nicely. It's good for up to 800 hp. I'm selling it because I need something lighter. here is a clip of how it sounds
2x OEM Front seats - $5,000 for both
2x OEM Doors white - $5,000 for both
1xOEM Bonnet white - $3,000
2xOEM Turbo Chargers - $4,000 for both
Give me a call or email if your interested.
0418 290 615
[email protected]
Miles..
  • Replies 227
Dodson built transmission for sale. CLICK HERE!
I have a fully built Dodson GR6 transmission
Parts list below, pretty much the full Dodson Catalog.
our race only car is going to a lightweight specially adapted rear wheel drive transmission which is a change in direction after our new transmission was just finished being built in December. The transmission has never been used (other than the standard Run in and check by the Dodson authorised Technician test car). Also has all the new Dodson tranny and diff oils. ATS Carbon Rear diff.
All the parts are brand new. Read: Brand new promax clutch, Brand new 1-6 straight cut greatest. and all the parts listed below.
We also have a a billet transmission selector fork installed (this is the fork that failed in my transmission originally)
I don't need a transmission swap but will consider if it makes the sale.
The full build cost and supply of a second hand transmission would fetch AU$55,000
Will sell for $49,000.
Steve Thatcher From JustJap in Sydney (the Dodson authorised australian technicians) will happily answer any questions/verify the work and the install. his email is:
Steve Thatcher [email protected]
R35 CPM PRO MAX COMPLETE CLUTCH 1000 FT/LBS+
R35 MC1 2MM MECHANICAL CIRCLIP 1 2MM
R35 MC2 MECHANICAL CIRCLIP 2
R35 GL GEAR LOCK FOR FWD TRANFER GEAR
R35 ORK O RING KIT
R35 OPK OIL PUMP UPGRADE AND REPAIR KIT
R35 DCS HIGH TEMP DIFF SIDE COVER SEAL
R35 TP BILLET ALLOY TRANSMISSION PAN/SUMP includes R35MK
R35 TF TRANSMISSION FILTER REUSEABLE
R35 TFP TRANSMISSION FLUID + 30 DEG AMBIENT
R35 DO1 HEAVY DUTY DIFFERENTIAL OIL
R35 ETS ENGINE TEMP SWITCH 68 DEG C
R35 RSS HEAVY DUTY CLUTCH RETURN SPRING SEAL
R35 OPP OIL PUMP END PLATE AND GASKET
R35 6SGS SC 6 SPEED GEAR SET STRAIGHT CUT
R35 FWDCH FWD UPGRADED CLUTCH HOUSING
R35 FWDCP FWD UPGRADED CLUTCH
R35 FWDP FRONT WHEEL DRIVE PINION
R35 FOS FWD OUTPUT SHAFT
Guys,
Ive also got 4 brand new Front & Rear Nissan OEM Brake Rotors.
They did about 1500kms on the car before being switched out to AP J hooks.
I'll sell them for $500 each or $1500 for the lot.
Thanks.
Miles.
0418 290 615.
hi all have a set of RS-D up for sell
20 x 9.5 +40 x2
20 x 10.5 +12 x 2
colour is black with chrome lip
condition is (brand new condition) no marks or scratches on the lip or spokes itself
remarks: only lock nut mark inside the lock nut hole.
asking $4900
1331547821[/url]' post='6271583']
R35 ORK O RING KIT
Price drop
$45,000 without tranny swap
$37,000 with a good condition tranny swap
Hi everyone,
I have for sale a brand new OEM Nissan R35 GTR car cover with carrycase. Purchased from USA but was never used.
Asking $300, however open to offers. Below is the ebay link;
My link
Item is located in Norwest NSW 2155 (just off the M7).
If your interested please contact me on 0411 415 644.
Rohin
ok standard width top racing front bumper and carbon fenders going out the door $3500 for the lot excl shipping. otherwise they are off to Dubai by next week!
thats AU7000 of carbon parts adn AU2000 shipping from hong kong - its a steal
Hi mate,
Is this still available? I am in Hong Kong and can pick up from Top Racing.
Thanks
Rob
Have a zele style rear CF diffuser for sale. Purchased for $800. Selling for $650 pickup. Brand new, never fitted. Pickup from the hills area or you can organise your own courier.
Reason for selling - decided on another item
PM if interested
Hi Guys, Sold the R35 and have left
a brand new Greddy R35 motor shrink wrapped that I kept as a spare, $14,000
a set of brand new set of Run flat R35 tyres from USA in plastic $2000
Im in Northmead near Parramatta Sydney NSW.
Dom 0414 62 62 43
And the new race car has 306.1 kwatts ATW weighs 100+kgs less than an R35 and does eastern creek in about 2 mins in the dry and 3 mins in the wet using 3 sets of rear tyres per lap. But boy is it fun.
So what is it?
Dom 0414 62 62 43
So what is it?
Wow you must change tyres quickly.
Tyres sold, I just have DMS coil overs and Greddy engines which are built exactly to new and stock but blueprinted and balanced.
Greddy is the performance house in Los Angeles and no aftermarket parts were used all brand new Nissan parts.
  • 3 weeks later...
2 x 2008 model Black Edition GTR seats (grey with red inserts) in as new condition
1 x 2008 set of brakes (several sets of second hand discs AP/stock mainly stuffed) - all working fine 12,000km from new
1 x 2012 set of brakes as new (travelled under 100km)
Make me an offer....
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
