Hi people, just wanting to hear peoples thoughts on High Octane coatings. I have used Competition Coatings, HPC, Jet Hot in the past and have my thoughts on the respective pros and cons of them....I have not used High Octane coatings in the past.
Anyone used their black manifold/turbine housing coating and can speak to its durability?
http://www.performancecoating.com.au/turbocharger-coating
My own experience has HPC the best for quality and durability...no surprise they are they most expensive. Competition Coatings and Jet Hot about the same, with perhaps Jet Hot being a tad more durable but less range of colours and finishes.
I've used Techline ceramic coatings on my manifolds and turbine housings on 2 of my cars. Coatings are inside and out of the manifolds and turbine housings.
I've proven the coatings hold up to sustained heat around 850 degrees no problems. Looks good too. I don't know who of the companies you mentioned use the techline products, but the key is in the application. I have an aluminium oxide/ceramic base under the black TurboX coating.
Competition Coatings did a set of CP pistons for me in one of my other engines. The finish looked great. Never produced any performance data with that engine though. Changed the recipe before getting that far.
I used a local ceramic coating a few years back. The ceramic held up but i swear the black that i paid extra for was just heat proof paint. After tuning on the dyno the black was peeling off from the collector.
ive used competition coating for my manifold and turbine housing, the high temp black one,
seems to have reduced my coolant temperature a fair bit , could be the larger turbo contributing though, seems ok so far.. not fancy to look at though, just faded black looking..
craved coatings did mine too, after a couple of dyno pulls the exhaust housing was measuring 300c on the surface (manifold and housing ceramic coated a cast iron/gunmetal grey colour inside and out)
competition coatings did both my manifolds, both sides of my turbo, cooler piping, TB and dump pipe.... looks sick and works really well... Ive got a few lines which are really close to my dump pipe and im so supprised that they havnt melted... without the coating im sure they would have.
All encouraging, but how long have you been running the manifold, turbine housing coatings. This ca is driven around 1000kms a month and does some sustained wide open throttle stuff so will get plenty of heat in it doing some fun days at the track. I have decided will be givign Comp Coating a go in Coburg and see how they go
    • Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this. Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't". Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed. Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod. Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
    • Yes I'm going through a similar thing with my R33 with rust in seams due to dried out seam sealer cracking. After much research I settled on Penetrol. Read what it does and its done a bloody fantastic job for me. Pressure pack comes with a thin tube to get into hard to reach places.
