  • Replies 118
Posted Images
The process goes like this:
Buy turbo rb20 32
remove turbo
Replace with standard manifold for increased backpressure
Install straight pipe with blast pipes.
Mig up the diff
Go chuck skidzzz ;)
Still registered as Turbo.
Still get F'd In the A by the 5-0.
Also, you left out the step where you install a BW 3 speed.
All noobs.
I say buy an r34 GTR and remove the turbos when on your Ps. That way once you are off your Ps you can put the turbos back in and decimate all in a 1/4 mile race that will take 60 seconds or so... You just have to make sure the manifold is tough, because you may blow the welds to the intake causing piston rings to fry and your floor pan falling out.
:wub:
All noobs.
:wub:
This guy lives his life a 1/4 mile at a time
Sau, Yes he probably asked a stupid question or whatever he did, but to him its something hard to figure out so he asked you guys for advice, yes he should of used the Search function but yeah. To you it may seem like something so dumb, because the topic probs, been done to death. But you should consider, that hes young like me and just wants to unravel something thats spinning around in his head. Flam him, but help him at the same time. Otherwise hes just gonna ask the same question again, just with different words. So put your head in.
Where was this support when I first asked about getting a R34 for my first car? Barely got any replies :(
But seriously to OP, if your genuinely non-trolling and want to get a 34, get yourself a GT or 25GT (correct me if I'm wrong guys, the 25GT is the RB25DE?). It's non-turbo and a good car to drive. My 34 in my sig is my first car, have driven with cops, tailed to and from and never have I been pulled over once.
If you're serious about getting one, I'm happy to give you a lift in my free time so you can get a feel.
And to answer your question, the only R34 you can drive on your P's is the GT/25GT. Pretty much the same with the GTT but without the 3 center dash gauge, exhaust system may be a little different and other little mechanical things that won't really matter to you at this stage. I'm not going to go into the GTR's since that's all I know for now.
And about the cop scanner, LOL. Never knew Need For Speed radar technology existed in real life. But if it does exist, then I'll be damned :domokun:
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
