  • Replies 118
Posted Images
The process goes like this:
Buy turbo rb20 32
remove turbo
Replace with standard manifold for increased backpressure
Install straight pipe with blast pipes.
Mig up the diff
Go chuck skidzzz ;)
Still registered as Turbo.
Still get F'd In the A by the 5-0.
Also, you left out the step where you install a BW 3 speed.
All noobs.
I say buy an r34 GTR and remove the turbos when on your Ps. That way once you are off your Ps you can put the turbos back in and decimate all in a 1/4 mile race that will take 60 seconds or so... You just have to make sure the manifold is tough, because you may blow the welds to the intake causing piston rings to fry and your floor pan falling out.
:wub:
All noobs.
:wub:
This guy lives his life a 1/4 mile at a time
Sau, Yes he probably asked a stupid question or whatever he did, but to him its something hard to figure out so he asked you guys for advice, yes he should of used the Search function but yeah. To you it may seem like something so dumb, because the topic probs, been done to death. But you should consider, that hes young like me and just wants to unravel something thats spinning around in his head. Flam him, but help him at the same time. Otherwise hes just gonna ask the same question again, just with different words. So put your head in.
Where was this support when I first asked about getting a R34 for my first car? Barely got any replies :(
But seriously to OP, if your genuinely non-trolling and want to get a 34, get yourself a GT or 25GT (correct me if I'm wrong guys, the 25GT is the RB25DE?). It's non-turbo and a good car to drive. My 34 in my sig is my first car, have driven with cops, tailed to and from and never have I been pulled over once.
If you're serious about getting one, I'm happy to give you a lift in my free time so you can get a feel.
And to answer your question, the only R34 you can drive on your P's is the GT/25GT. Pretty much the same with the GTT but without the 3 center dash gauge, exhaust system may be a little different and other little mechanical things that won't really matter to you at this stage. I'm not going to go into the GTR's since that's all I know for now.
And about the cop scanner, LOL. Never knew Need For Speed radar technology existed in real life. But if it does exist, then I'll be damned :domokun:
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
