What Spark Plugs To Use?
Mate, if Australian build quality was an eye opener, wait until you try a Chrysler. If you need space and fuel economy (and you don't want to hit the track) a fuga hybrid is the way to go. Similar power to the 400r (270kw), roomy, comfortable, good on fuel, great build quality
Um...self respect?
Um...that thing looks terrible. I'd be looking for replacements tout de suite. WTF is it made of? Die cast cardboard?
By drifter17a · Posted
Found it thanks, the front tie rod end should be torqued to 40nmish -
Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good appreciate the help chaps
