Hey Guys & Gals,
I have had these parts sitting around my garage for ages and need to get rid of them.
Prices are negotiable within reason. Pickup is preferred however I can post some of the smaller items interstate if required.
R33 GTR Standard Airbox and Snorkel w/ Bolts $150
http://imageshack.us.../img00511j.jpg/
http://imageshack.us.../img00501t.jpg/
R33 GTR Wing End Caps $40
http://imageshack.us...3/img00491.jpg/
R33 GTR Standard Wing Blade (White) $80
http://imageshack.us.../img00541v.jpg/
R33 GTR V-Spec Standard Suspension (Removed at 90,xxxkm functioning) $250
http://imageshack.us.../img00561a.jpg/
R33 GTR V-Spec Computer (Removed still functioning) $100
http://imageshack.us.../img00551b.jpg/
RB26DETT Standard Inlet+Exhaust Cam Gears $80
http://imageshack.us...2/img00481.jpg/
R33 GTR OEM Orange Side Indicators w/ Bulbs $40
http://imageshack.us.../img00471y.jpg/
R33 GTR OEM Floormats $50
http://imageshack.us.../img00531e.jpg/
R33 GTR Fibreglass Eyelids (Silver)
http://imageshack.us.../img00521y.jpg/
2 x Dunlop SP Sport 9000's 255/45R17 Approx 85% Tread Remaining $12
PM for contact information and any questions.
Cheers,
Justin
https://www.sau.com.au/forums/topic/405049-r33-gtr-stock-parts/
Update:
Airbox SOLD
End Caps SOLD
Computer SOLD
Still have Tyres, Suspension, Indicators, Cam Gears and Wing Blade.
Tyres are to suit standard R33 GT-R wheels.
Cheers!
  • 2 months later...
