  • Replies 123
Posted Images
Heard somewhere that the G37 will only come in around about Dec 12 or Jan 13. Initial launch will be for the FX SUV.
Once the G37 comes in, based on my understanding, we can no longer import cars "manufactured" in Japan after that date (i.e Dec 12). Still gives us a good 3 years worth of imported supply once the 2012 Japanese models become due for their shaken in 2015 and come on the auction market. :D
I'm expecting the value of our cars to increase by anywhere from 20-50%. This is why I'm rebadging mine as an Infiniti. :)
Value won't increase if your car has 200K on the clock, the older it gets the more money you will lose. Unless it's something like a 65 Mustang..
I'm comparing apples with apples mate. Cars do depreciate however when these vehicles come over here and the base value is raise significantly and if the scarcity still exists, then we have the opportunity to make some mooolah! I've taken a look at the forecasts and feasibility of this, should work well...
I do agree with you though, you would think these cars will appreciate slightly since we won't be able to get them anymore.
Doubt the existing models will appreciate in value much.. if you can still import a 2012 370gt coupe for $40k-$50k in a year or so time, people aren't going to pay $60k-$70k for one locally when they can import their own much cheaper.. with the exception of a few people with more money than brains..
I was talking more about the V35s. Avg value C$20k (to keep it in round numbers). Once the 370GTs are released here for an absolute mint, people would be more accepting to pay towards $25k-$30k for the V35. Don't get me wrong, I'm not saying that you will definitely experience a 100-200% boost in value - that's just stupid... However, an extra 20-50% - very likely.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
