So,
If I boot it and then stop shortly there after, I get a sulphur smell in the car. Also if I go up a really steep hill on approx 2.5-5psi, so just holding revs while going 110 that same smell creeps into the car.
My cat is only about 6k km old.
I have also tightened up the bolts around the cat.
What else could be causing me this stinky smell?
https://www.sau.com.au/forums/topic/405107-why-do-i-smell-egg/
It's most likely nothing to worry about mate, most petrols have sulfur in the additives. Some are better/worse smelling than others. Are you filling up from the same petrol station every time, or have you recently filled up at a station you don't normally fill up at?
Ah indeed it is a 100cell cat. stupid cat.
My next suggestion was going to be maybe you left some fried rice in the glove box after a night out at Golden Palace so I'm glad it's a 100cell cat.
The fried rice will tend to change smell anyway and I've only had that problem twice before so it's not common in the Skylines
Haha, didnt even think a container of fried rice could fit in the glovebox.
Ah well, the life of running a cat i spose. Decat pipe one day
On the topic of cats, my cars been tuned on no cat, im fitting a 100 cell cat, with a 4 inch body on a 3 inch pipe, will it change the tune much? and for lean or rich? Im getting a retune after just not sure if I should baby it before tune with new cat. Running 338kw on 22 psi. On caltex 98
Any help would be good thanks
Depends on how much it flows, if it is a restriction then it will change the load points. But if it's a well flowing cat then it shouldn't change the tune much at all. I did a back to back test on my car with the exhaust on/off from the front pipe back, made hardly any difference.
Safest to get it checked first, but you shouldn't have to baby it TOO much.
just for sake of conversation my work ute does this too but only sometimes. its an 04 holden rodeo 3.5l v6 and the only unusual thing about this car is that it chews through the oil. i will do an oil change or really top up about every 4 months and only about 500ml will come out. so, maybe the smell might also have something to do with oil consumption.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
