I have tried to search but didn't find the thread I was after.
There was a guy on here who had just fitted an intercoolerguy hyrid to his R33gts25t i think with some good results maybe 20kw?
I already have air filter, boost and twin dump 3 inch turbo to tip. So am thinking about getting a FMIC next. I have heard good things about
ARE and they are close to me also. I have confidence that theyll do a good job but from what I can see I will have to spend about $2k.
Is this necessary. Eg the Intercoolerguy has his hybrid delivered for $1150. Myabe for my purposes this is ample. Im not after 11 sec 1/4, more after a nice handling street car with good response and daily driveability. Lergo can't see me going beyond 250rwkw.
So do people have good reports on this hybrid IC. Will it be ample for up to 250rwkw with supporting mods.
Thinking of getting that delivered for $1150 and getting ARE to fit it for $280 (although thats to fit there kit). Will they run into any probs installing the hybrid?
https://www.sau.com.au/forums/topic/40511-intercooler-advice/
Dude, me and a mate have fitted 2 ARE FMIC kits both to R33's they are a piece of piss..directly bolt upto the front, only fabrication is the 80mm hole drilled underneath the washer bottle. which is done in a variety of ways and that way it leaves u with a nice hole to run ur CAI pipe near the pod filter.
if you need around 250rwkw get a stock r33 or r34 gtr intercooler. ive been told they are good for upto 300rwkw. should cost around $600 ish not including piping and fitting. probably a better cost effective setup vs a brand new front mount kit
Yea but then we get into 2nd hand could be a dodgy cooler territory. If there was some guarantee I wouldnt hesitate esp cos of price.
Im guessing that a stock GTR cooler would also not have the same cooling potential as a ARE or intercoolerguy new one.
Better to have it and not need it, than to need it but not have it. You've got me thinking though.
well thats not always true. having a bigger intercooler that you need doesn't mean its better. fit a truck intercooler and watch how long it takes to flow it enough. you wont loose power getting a bigger one but it will take longer to flow the air thus more lag is added to the system.
get a suitable size for your kw target, not point getting bigger just becasuse its bigger. a 2nd hand gtr cooler should be fine, specially from an r34. it will flow better then a bigger front mount for around 250rwkw or thereabouts, it will probably be better suited for that kw target. sydneykid showed me a thread on the comparsions somewhere, search for it. i would stick with the stock gtr cooler (from 33 or 34) until my target was over 300rwkw or thereabouts
when looking at buying a i/c i found that paying for a jap_spec kit e.g apexi, trust, hks was a better opinion to Hybird type i/c
A japspec kit can be had from around 1.3k, this inc piping but not shipping.
was quote For Hyber $600 for i/c and $600 for piping so it is around the same price
if you are paying 600 for a hybrid in perth you are getting ripped... go see xspeed , works , etc ... no way are they 600... piping makes it about 1100 all up... add shipping to a trust apex hks kit and it wont be close to that... and like i said for 250 rwkw you wont need a "real" brand cooler.
i have the intercooler guy fmic kit on my r31, its BLOODY AWESOME, instant power, FREEZING cool air and no pressure drop, not to mention it looks bloody awesome.. all i can say is get one now!! cause i fit it myself onto a r31 and its a r32 kit, so should be peice of piss to fit it to a car its made for.... His names Julian, hes a top bloke, call him tell him brett from the gold coast sent ya he will look after you
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
