Did this mod, takes a long long time to do it right. I ran 50 amp wiring and a 70 amp relay (incase i go e85 twin pumps) to my 400L walbro, all works. (it doesnt work if its hooked up backwards :unsure: and the pump sounds funny.) but hooked up correct polarity and presto.
Question, which fuse? im running a 25A atm, is this right??
And will I need a fuel cooler?
That sounds like the wiring setup I installed, slightly overkill but at least you never need to do it again. The fuse is to protect the cable, and the pump may draw close to that on startup seeing as it draws up to 18 amps in operation. I would go for a 30 A fuse at least, actually I went with 2 x 30A fuses for my twin 342 pumps.
I need a cooler for the flow the twins are putting out, (similar flow to the 400L) but it takes over an hour of driving to heat the fuel, are you doing long distance driving with your car?
Haha I did the exact same thing with the polarities! :P
+1 for 30A.
I live 2 hours from any city lol so mostly 100+ km/h driving on highways.. Whats the giveaway that fuels getting too hot?
Mine heats up much worse in city driving as there is no under car cooling, on the open road it takes a lot longer. I still have to find a nice 6an trans cooler for the return and then find space to put it, I also need to fit the ethanol content sensor in the return line somewhere. Always so much to do and no time to do it.
Just feel the tank, mine felt hot to touch last time I was at Calder.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
