My control panel has failed, I know what is wrong and how to fix it.
The problem with mine is the toggle button split and I've fixed it twice before but now the whole toggle has disintegrated and I'm finding it hard to even buy a replacement panel.
So I'm hoping that someone out there has an old panel that they have replaced and i could use to fix mine, all I need is the plastic part that screws to the circuit board with the buttons on it.
I am currently still using mine without the button panel by manipulating the switches with my finger which works fine but is quite distracting while driving.
I know there are differences between series 1 & 2 but that is the circuit board and as far as I can see the buttons lay out are the same so either one will do for now.
Thanks for any advice in advance.
https://www.sau.com.au/forums/topic/405175-r33-window-control-panel/
Hey mate are you talking about the whole driver side window switch and the surrounding black panel?
If you are I have a spare lying around that I was wanting to sell on the cheap anyway. It's for a series 2, all buttons are working (only the driver auto down click a little floppy) and the panel is slightly chipped.
If you're interested, pm me!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
