Hey all, got pulled over today by the police, ended up with defects
Blow off valve
No air box pod filters
Ride height
Bonnet modified beyond manufactory spec.
Queries are my car has a 30/25 in it and to clear these defects I'm requested to do a blue slip.
The car was engineered but not for the new motor. Will I need to aquire a new report for the 30/engine?
https://www.sau.com.au/forums/topic/405203-blue-slip-engineer-cert/
Thanks, found out apparently I only have to get the defects cleared on the notice and not a blue slip. Think once they are cleared I will look into adding the engine to it.
Few other things the officer said to me which I kinda found funny was, he asked were the strut brace was I said it had been removed before I purchased the car. His response get it back on there it's engineered for it so it HAS to be on the car along with your carbon fibre bonnet, which he also questioned the were Abouts aswell.
He also tried to explain that my turbo was to big for the motor and that it will over boost and blow up due to the size of the turbo.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
