so stripping my baby to stock to sell it....
all parts are loctae din vic and i can post all items anywhere in aus if you pay...
my mobile is 0430078630 sms preferred
Genuine bee r's painted silver/grey..... genuine stickers
17x9+22 fronts federal 215/40/17
18x9.5+22 rears federal 215/40/18
2.5k firm
apexi evc fits my 3 inch exhaust.
$200
2way diff not sure on ratio. 5 bolt...r200
$800 or $650 and your stock or welded diff.
r33 gtr s2.purple sticting seats only one little ciggie hole...perfect seats
fit my r32 perfect,
$1200 or can swap for your stock seats plus cash my way
adjustable whiteline sway bars front and back
$300
hicas lock bar..
$50
adjustable cam gears x2, silver for rb's
$250
r32 slotted rotors fronts only
$150
oil cooler setup from fultuer motorsports.bigger cooler from just jap.
relocation and cooler..
$350
led lights rear pair
$200
Blitz gauges x4...oil temp.oil pressure..water temp. boost,
i have not hooked up the water ever.
awesome gauges love them to bits. glow blue at night.
$700 all senders/sensors and wiring included.
  • 5 weeks later...
bump Genuine bee r's painted silver/grey..... genuine stickers
2.5k ono
$200
r33 gtr s2.purple stitching seats only one little ciggie hole...perfect seats
fit my r32 perfect,
$1100 or can swap for your stock seats plus cash my way
$300
hicas lock bar..
$50
$250
$150
$350
$200
  • 3 weeks later...
2.5k firm $2000 or swaps for 17's have to be decent wheels and offsets no stupid rotors, drift teks etc
Bump
Really want the gauges gone..
Also adding genuine gtr boot with genuine gtr boot wing $300 paint is perfect and colour is white.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
