Hey guys,
I had my rb26/30 tuned yesterday after finishing the build on it finally, all running well. I bought a rb26 reconditioned head for it a while back that supposedly had camtech cams in it. The person I bought it from also told me it had springs.
Long story short it's running fine, but the head is "noisy". I was told the clearances need to be done by the tuner, and he's probably right. I take it this means the shims all need to be checked yes?
So my questions is, I would like to chuck in a set of Tomei Pro Cams, 272's with 9.15 lift. Without taking all the head apart, how can I check if it has better springs in it?
The idea is to chuck new 272's in it, then do the shims at the same time but I will obviously need better springs for the 272's which hopefully already have. The camtech cams had serial numbers etched into them, but I am still sus on the springs being stockers.
It there a tool I can get to check the spring rate?
Cheers.
https://www.sau.com.au/forums/topic/405243-rb26-spring-rate-and-cam-question/
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
