Hey.. Just looking up coilovers, i'll probably go with the BC BR's for my R34 GTT but just wondering if anyone has heard anything about these Emotion coilovers - http://www.ebay.com.au/itm/EMOTION-SUSPENSION-COILOVER-DAMPER-KIT-F-R-NISSAN-SKYLINE-R34-GTT-1998-2001-/120940699640?pt=AU_Car_Parts_Accessories&hash=item1c28a09ff8#ht_1310wt_922
Cheaper by $125 so i know i'd be best to go with the tried n true BC's but just thought i'd ask.... Mainly want coilovers to lower my car a few inches and also stiffen the suspension up for street use and the occasional track day. Cheers.
I'd been searching coilovers as I've just stuffed my rear ones in the GTT, could get them rebuilt but I think I'll just go to the BCs... The link shows they are from a warehouse type place which means tech support or warranty if anything goes wrong is probably limited, also doesn't mention if they are able to be rebuilt etc..... I would suggest sticking with the tried and tested product ;)
BR mate..... A few that have them said they are worth the extra $150 up from the entry level...... They are only $1299 delivered from what i can find, unless you've seen any cheaper?
Hey Chris,
Email Street to Track, for the BC BR coilovers they are $1165 delivered which is cheaper than any i have found in Aus :D
[email protected] or www.streettotrack.com
Hope that helps you!
Yep, BR's mate. You'd be crazy to get the V1's for the sake of $100.
And that price that Matt found, that's crazy stuff!
Yep was about to order at $1299 and then did a last minute google which led me to a Scooby forum and then onto Pauls website! SCORE!
Well I put $500 down on a laybuy for a set today, once the missus gets her tax i'll pay the rest... She's buying them for for coz i'm a top bloke hahaha... got em for 1250 trade.
I love them
Did you have other coilovers in the car prior? For a comparison? I've been running Teins and I was told they are similar.....
Ive ran coilovers in other cars, the gtr was upgraded from good old stock vspec suspension. And ill tell you on half dampening stiffness, these BC BR's are more comfortable.
I was also in my mates 32 with teins and far out they were stiff as f**k
Mine aren't too stiff, it's just the rears that shat themselves.... Really looking forward to these now.... Is there a recommended dampner setting? I read some are stiffer in the fronts?
You won't regret it man, the BC's have a really good range of dampner. On full soft they are really comfortable, bit stiffer than the old King springs that used to be on mine. On full hard they are rock solid, but not as hard as the Tein's wound all the way up.
I was told when setting mine up to have the dampner at the front a little bit harder, to compensate for the weight of the engine. So I usually have my fronts on about 22, rears on 15. I soften them up a bit when I go to the track.
How do you work out what spring height adjustments before you install them, or is it a matter or adjusting them in the car?
The way I did it was I had a basic idea of how much further I wanted to lower it when I installed them, then I set them to the same height as my old springs and then lowered them by how much I wanted. That was with everything out of the car. Then when I lowered it later I did it on the car. Takes about an hour or so to do on the car, so it's no big deal. Just getting all four corners the same can be a bit tedious.
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
