Hey.. Just looking up coilovers, i'll probably go with the BC BR's for my R34 GTT but just wondering if anyone has heard anything about these Emotion coilovers - http://www.ebay.com.au/itm/EMOTION-SUSPENSION-COILOVER-DAMPER-KIT-F-R-NISSAN-SKYLINE-R34-GTT-1998-2001-/120940699640?pt=AU_Car_Parts_Accessories&hash=item1c28a09ff8#ht_1310wt_922
Cheaper by $125 so i know i'd be best to go with the tried n true BC's but just thought i'd ask.... Mainly want coilovers to lower my car a few inches and also stiffen the suspension up for street use and the occasional track day. Cheers.
I'd been searching coilovers as I've just stuffed my rear ones in the GTT, could get them rebuilt but I think I'll just go to the BCs... The link shows they are from a warehouse type place which means tech support or warranty if anything goes wrong is probably limited, also doesn't mention if they are able to be rebuilt etc..... I would suggest sticking with the tried and tested product ;)
BR mate..... A few that have them said they are worth the extra $150 up from the entry level...... They are only $1299 delivered from what i can find, unless you've seen any cheaper?
Hey Chris,
Email Street to Track, for the BC BR coilovers they are $1165 delivered which is cheaper than any i have found in Aus :D
[email protected] or www.streettotrack.com
Hope that helps you!
Yep, BR's mate. You'd be crazy to get the V1's for the sake of $100.
And that price that Matt found, that's crazy stuff!
Yep was about to order at $1299 and then did a last minute google which led me to a Scooby forum and then onto Pauls website! SCORE!
Well I put $500 down on a laybuy for a set today, once the missus gets her tax i'll pay the rest... She's buying them for for coz i'm a top bloke hahaha... got em for 1250 trade.
I love them
Did you have other coilovers in the car prior? For a comparison? I've been running Teins and I was told they are similar.....
Ive ran coilovers in other cars, the gtr was upgraded from good old stock vspec suspension. And ill tell you on half dampening stiffness, these BC BR's are more comfortable.
I was also in my mates 32 with teins and far out they were stiff as f**k
Mine aren't too stiff, it's just the rears that shat themselves.... Really looking forward to these now.... Is there a recommended dampner setting? I read some are stiffer in the fronts?
You won't regret it man, the BC's have a really good range of dampner. On full soft they are really comfortable, bit stiffer than the old King springs that used to be on mine. On full hard they are rock solid, but not as hard as the Tein's wound all the way up.
I was told when setting mine up to have the dampner at the front a little bit harder, to compensate for the weight of the engine. So I usually have my fronts on about 22, rears on 15. I soften them up a bit when I go to the track.
How do you work out what spring height adjustments before you install them, or is it a matter or adjusting them in the car?
The way I did it was I had a basic idea of how much further I wanted to lower it when I installed them, then I set them to the same height as my old springs and then lowered them by how much I wanted. That was with everything out of the car. Then when I lowered it later I did it on the car. Takes about an hour or so to do on the car, so it's no big deal. Just getting all four corners the same can be a bit tedious.
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
