hi guys im after sum help/info on a exedy xtreme daiken clutch part no: R5028NHD.
my car runs 210kw and just want to know if this will be ok to use and handle the power?ive searched google and the exedy website and i cant find out much about it so any help would be great
this is the only info i could find:
There are two heavy duty organic kits. First one is part no:
( R5028NHD ). Which is a new assembly the cover is pivot modified for increased clamp
https://www.sau.com.au/forums/topic/405267-r33-daiken-clutch-r5028nhd-infohelp/
Just when you think life has become easy by having all the information provided, someone pops a curve ball at you and you scratch your head
The NSK-7056HD is the only Heavy duty part number Exedy list. There are sports organics and other heavy duty options but they are all 7056 except the Hyper metal range. Your part number is incorrect.
Get the NSK-7056HD - it will serve you well at those power levels - as has been mentioned dozens and dozens of times on this site
The part number is correct but it is a daiken part number and now that exedy has taken over daiken id say they have changed them all so i might have to ring exedy and see if they have a cross reference to the old numbers
You are referring to a part number that is something like 15 years old. NSK-7056HD is the current number.
NSD-098U clutch plate was in the R5028NDH kits (over 10 years ago). These days you can save some money and buy the NSK-6797HD kit which will do the same thing
ok cool cause the clutch kit i have is brand new and the clutch plate in the box is part no:nsd-098u which is in the r5028ndh kit.sorry mate i was under the impression that exedy had taken over i wasnt tryn to be a smart ass.so is the clutch kit i have any good?will it last a while and will i be expecting a heavy peddle?thanks heaps for the info uve been a great help.
I know you're not being a smart ass. That part number is not one used by anyone any more - although some catalogues still contain the old numbers for this reason I think.
The clutch you have should be ok for 240-250rwkw safely for a few years. Pedal feel should be heavier than standard and definitely a lot heavier than your worn out standard clutch
i have a exedy cushon button clutch at the moment will peddle feel be similar?will this suit my r33 cause the nsk 6797 exedy clutch u are referring to on the exedy website says it is suitable for r31 and r32 but not mine.sorry for all the questions
Yes the pedal feel will be similar pressure but slightly less bitey than the cushion button.
The NSK-6797 is exactly the same clutch but the centre hub has large single springs from memory. The NSD-098U clutch plate has smaller double springs in the hub.
It could be the other way around though it's been a while since I cared enough to look. Both are equally as good and both will hold the same power. The double spring one is softer to drive on compared to the heavier single spring variety but it's really not noticeable
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
