Rb25/30 Long Engine, T67-25G Kando & Tial W/g, Freddy Intake & 80Mm, Power Fc & Nismo750Cc
Will only seperate parts once engine is sold!
RB25/30 Long motor rebuilt november 2011,
Reco head with welded vtc and waterjacket, RB20 inlet cam, 25 exhaust cam, metal head gasket.
Linished std crank, crank collar, N1 oil pump, New acl bearings and moly rings on std RB30E pistons & rods.
1.2mm restrictors, block drilled, lightly honed. New Exedy HHHD clutch, timing belt, idlers and waterpump.
Can see running and fitted to vehicle.
$1650
Kando T67-25G with Tial MVR 44mm wastegate mounted off exhaust housing.
Includes modified stainless top mount manifold, dump and screamer/flanges/flex.
Turbo 4months old & still under warranty.
Fitted to vehicle and only for sale once engine sold!
$1250
Freddy RB25 inlet manifold & 80mm throttle body, modified to clear R32/S13 master cylinder.
Chrome outer and machined face, Tps & 3' intake pipe/hoses included
$450
Apexi powerFC suit rb25
Includes hand controller, Z32 afm & k/n pod filter.
Tuned by Pits - Rb25 with Z32 afm with 80mm throttle,750cc & Gt3037s with .63.
$1000
Nismo 750cc injectors in modified fuel rail with twin feeds.
$600
Splitfire coilpacks suit series1 R33 Rb25.
$350
Greddy GREX oil cooler kit
big cooler, thermostat and filter relocator, New Russell braided hose
$550
R32 40mm Alloy Radiator & 16' electric fan
$220
All parts are currently fitted to my R32 and I drive it everyday to work.
No dyno sheets, No tyre kickers & No bullshit!
Very aggresive and No knock even on 14psi
Heaps of quality R32 parts available!
Will sell all $5500 CASH and include spare RB25 long motor!
Gold coast
Sam 0423 648 114
Edited by 32TAXI
Story of the 25/30!
The old rb25 had leaky valve stem seals and smoked on hard decel, but still had even comp on all.
So weighted it up to rebuilt a 25 or 30 but scored a 30 Short block, collar, cometic head gasket, new waterpump and 2x 1.2mm restrictors cheap off SAU so it started.
Bought a spare 25 head, welded water passage and vct then got full reco and 2x valves by Gilberts.
Got a New genuine N1 oil pump and Nissan gasket set, Acl bearings and Moly rings from states at the right time. Crank was sent to Probuilt, Grubscrews and collar fitted, checked and linished.
Gave the block a good clean, drilled, restricted and a light hone(slight top ring wear)Standard bores, deck and crank, new dayco belt and hi/lo tensioners, RB20DET inlet cam/sprocket as always wanted GTR covers!
I'm a Mechanic of 15 years at Nissan, In the trade as they say and was built cheap so sell cheap.
RB25/30 was built in november 2011, No forgies, No rods, supported well, never spun over 7k or 14 psi.
Just a tough street engine that pulls hard, very aggresive and runs great.
Needs a good balancer as never got around to it & VCT can be fitted via external line or internal mod if needed.
Edited by 32TAXI
What sorta deal u do on engine and turbo?
Call, inspect and go from there
Edited by 32TAXI
Motor, inlet and box SOLD
turbo, powerFC, injectors, oilcooler, splitfires and rad all available!
Edited by 32TAXI
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
