Will only seperate parts once engine is sold!
RB25/30 Long motor rebuilt november 2011,
Reco head with welded vtc and waterjacket, RB20 inlet cam, 25 exhaust cam, metal head gasket.
Linished std crank, crank collar, N1 oil pump, New acl bearings and moly rings on std RB30E pistons & rods.
1.2mm restrictors, block drilled, lightly honed. New Exedy HHHD clutch, timing belt, idlers and waterpump.
Can see running and fitted to vehicle.
$1650
Kando T67-25G with Tial MVR 44mm wastegate mounted off exhaust housing.
Includes modified stainless top mount manifold, dump and screamer/flanges/flex.
Turbo 4months old & still under warranty.
Fitted to vehicle and only for sale once engine sold!
$1250
Freddy RB25 inlet manifold & 80mm throttle body, modified to clear R32/S13 master cylinder.
Chrome outer and machined face, Tps & 3' intake pipe/hoses included
$450
Apexi powerFC suit rb25
Includes hand controller, Z32 afm & k/n pod filter.
Tuned by Pits - Rb25 with Z32 afm with 80mm throttle,750cc & Gt3037s with .63.
$1000
Nismo 750cc injectors in modified fuel rail with twin feeds.
$600
Splitfire coilpacks suit series1 R33 Rb25.
$350
Greddy GREX oil cooler kit
big cooler, thermostat and filter relocator, New Russell braided hose
$550
R32 40mm Alloy Radiator & 16' electric fan
$220
Complete 3.0 litre setup ready for your transmission in a silvia, skyline or whatever????
All parts are currently fitted to my R32 GTST and I drive it everyday to work.
No dyno sheets, No tyre kickers & No bullshit!
Very aggresive and No knock even on 14psi
Heaps of quality R32 parts available!
Will sell all $5500 ono and include spare RB25 long motor!
Gold coast
Sam 0423 648 114
Edited by 32TAXI
This is a bargain... Makes me depressed thinking I how much I have spent putting together a similar setup (without a 3L). Am I reading right that you are including 2 running engines in the $5500 package?
Yeap, All the shit plus 2x engines - 1x rb25/30 complete running, 1xrb25 spare long motor
My plans were to bolt 25 back in and go further with 30!
Basic bolt up to your gearbox in either R32 or R33 and GO!
p.s. Turbo in picture not included in sale
Story of the 25/30!
The old rb25 had leaky valve stem seals and smoked on hard decel, but still had even comp on all.
So weighted it up to rebuilt a 25 or 30 but scored a 30 Short block, collar, cometic head gasket, new waterpump and 2x 1.2mm restrictors cheap off SAU so it started.
Bought a spare 25 head, welded water passage and vct then got full reco and 2x valves by Gilberts.
Got a New genuine N1 oil pump and Nissan gasket set, Acl bearings and Moly rings from states at the right time.
Crank was sent to Probuilt, Grubscrews and collar fitted, checked and linished.
Gave the block a good clean, drilled, restricted and a light hone(slight top ring wear) Standard bores, deck and crank, new dayco belt and hi/lo tensioners, RB20DET inlet cam/sprocket as always wanted GTR covers!
I'm a Mechanic of 15 years at Nissan, In the trade as they say and was built cheap so sell cheap.
RB25/30 was built in november 2011, No forgies, No rods, supported well, never spun over 7k or 14 psi.
Just a tough street engine that pulls hard, very aggresive and runs great.
Needs a good balancer as never got around to it & VCT can be fitted via external line or internal mod if needed.
$1650
Parting out my modified R32 4 door sedan once engine sold
eg. 327AXI rego, 5 months rego, mod plated, no defect, rolling shell $3500, Safety21 4door 4seat 6point rollcage $1200, GTR front bar $500, GTR Bonnet $250, R33 5 speed g/box $1200, nismo 2way lsd $650, Tein HE driftmaster coilovers $900, cusco rear arms $250, RG tension arms $150, Adjust front upper $220, 28mm rear swaybar $ 250, Sabelt GT1 seats $650, Greddy profec b spec 2, greddy timer, pivot shiftlight, Nardi wheel + + + +
Edited by 32TAXI
Keen on the inlet mani and oil cooler, let me know wen ur ready to sell.
Motor and inlet sold
Oil cooler available $550
Turbo, power fc, injectors, splitfires and alloy radiator also available
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
