I have Tomei Sump baffle and a mines cam baffle going in, no sump extension tho, also an oil restrictor going in.
Might be alright for a streeter then, just overfill the sump by a 1L.
Edited by wedge_r34gtr
  • Replies 90
Sump baffle and Mines baffles isn't enough.
You NEED a big sump with a Nitto pump. End of story.
exactly, when you have a pump that can pump 65ltrs of oil per minute at 7000rpm, thats more then a ltr per second, how long do you think it would take to empty the stock sump
Hey guys, im looking at getting an N1 pump after what you have all said as i dont have the cash to get the sump and the big pump, what i was looking at doing was replacing the gears in the stock or the N1 pump with billet gears or Reimax gears, i have done some reading and the week point looks like its the gears being crushed under the pressure. Keep in mind my car is running stock boost, stock turbos, and its not going to be a track killer. In your experence would this make a better option or is there another pump that i can go for thats going to be stronger and not require the sump?
http://www.ebay.com.au/itm/RB26-Reimax-oil-pump-gear-upgrade-skyline-gtr-rb25-rb30-rb20-turbo-jdm-/261053373863?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc7fe5da7
Or would i be better off going with the stock pump and doing gears over the N1 hmmmm, trying to find flow rates for the N1 so i can compair to the nitto pump as i have read on here that they are close to the same flow rate and that defeats ther purpose of not getting the nitto pump.... wish i had the extra coin to do the sump to, sigh
  • 2 months later...
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
