I'm based down in Mandurah, but happy to travel for some great roads, prefer corners/hills lol... imported my GTT when I moved from NZ and it is now legally allowed on the road!
I've been out towards Dwellingup and to South Dandalup dam etc... some great roads out there... but what else does this state have to offer within a few hundred km radius?
Also, being new to the country, I know very few people, so I'm keen to get out and meet some of you!
Head to Bunbury, then go Donybrook, Balingup, Nannup, Donelly River, Bridgetown, then back to Bunbury via Balingup, or head out to Boyup Brook, cut through Collie via Mumbalup, then Southwest highway as far as Waroona, up to Nanga Rd and home via Dwelligup.
I get pants tent just thinking about that run :wub:
  • 1 month later...
Had a nice cruise out to Toodyay on the weekend, out via Toodyay road, back roads (not sure which) to Northam, was good. Back to Perth via Great Eastern was boring though, might want to detour through York if you have time. Perth-Toodyay-Northam-Perth was ~250kms.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
