An interesting build which we have been commissioned for. Take 1 x well used, 70,000km 09 ADM GTR and build it into a reliable daily driveable and mid 9 second package. First up to strip the car....
Dropping both engine and transmission out of the vehicle its time to start stripping them down and begin the process of making something ultimately more power and much stronger. Already this GTR with a small turbo upgrade on 98 octane fuel put down 385kw at the rear wheels
The stock engine although have a few kms under its belt was near perfect internally, with not a mark on the bores...which kind of makes the whole 80,000km rebuild thing look like the internet myth that it really was. This old girl looked like she could have gone another 100,000km without batting an eyelid
The new powerplant is a Greddy 3.8 litre combination we have put together with forged pistons/rods, head studs, and HKS head gaskets. This engine should have no trouble supporting 25 - 30 psi of boost pressure reliably - should it be required.
On top of the tough bottom end we are putting a set of Stage I cylinder heads, lightly ported, cleaned, and freshed in line with the rest of the engine.
Next we will finish the engine and build a tough and reliable transmission to hold the 550+rwkw this combination needs to put down :)
  • Replies 57
Engine was buttoned up today and most of the ancillaries put back onto it getting ready for installation back into the subframe. At the moment we are also rebuilding the bell housing to remove that annoying rattle many GTRs suffer from and toughen up the installation some. Everything is on track in this department - and notice the extended sump - important for high horsepower GTRs that may just well see a track.
With the engine being finalised its time to lay out the newest generation GReddy twin turbo kit featuring the cast manifolds to avoid any chance of cracking under high engine loads. It looks like a nice setup, but having a fair bit of experience with the GReddy kit we are making some of our own little engineering changes to make it even better!
The transmission had covered 70,000km and to the best of my knowledge had been on factory fluid all its life. While the gearset was in ok condition the selector pistons were rounded and worn which meaned we had to use our new WR35PC (Piston Clip) to ensure that these didnt turn and cause errors during operation. This is one of the reasons that the transmission was in fault mode when the vehicle was shipped to us (not a local Aussie car). Here is a picture of our fix -
This is very similar to the 'Nissan TSB caps' used when these transmissions wear prematurely under warranty. Note the transmission in the picture isnt the transmission out of the car, its a dummy up for the sake of the photo
Another part of the build we have undertaken for this car is the complete overhaul of the troublesome and noisy factory Nissan Bellhousing assembly. We modified it complete to make it fully floating so that it could never give any drama in the life of the car from here on in. Replaced the bearings, clips, sleeved it etc. It will be and remain to be totally silent now :)
If this kind of repair work isnt undertaken whilst the engine is out the bearings and crankshaft can be damaged long term.
good to see we have a local source for transmission/drivetrain repairs - i think most aussies are still adverse to mod'ing due to the stigma of the first US gearbox issues
ive read about the bell housing tsb in US, what exactly are the symptoms or noises to look out for?
Edited by domino_z
Got on track today with the installation of the GReddy turbocharger system on the GTR engine. This is a very neat install due to the kit being JDM and therefore engineered around RHD cars where most of the American product uses LHD as a base and generally runs smack/bang into the steering column of Aussie cars. Dont ask us how we know this! (much hair missing)
Greddy TD06 turbochargers using the latest generation cast iron manifolds. If you are putting turbos on your R35 then ensure you have cast manifolds....as getting at them if something goes wrong is an engine out job and takes a little time
Large 20G turbine wheels should flow enough air to see north of 550awkw without overly stressing the engine
Twin external wastegates mounted nice and tight to the bellhousing will keep the backpressure in the manifold down and the power up! :)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
