Interesting Build - Quest For Mid 9 Second Streeter
Martin Donnon
 Share
  • Replies 57
Sorry Domino, been a bit caught up with Targa Adelaide and all the associated work :)
This one is on the front-burner from here on in until completion. One of the 'tricks' we worked out is that to install the Greddy turbo kit you must have a Greddy top pipe kit as well! Thats done now.....
SD tuning only in something of this 'size'
This package has probably the best flywheel setup their is....we totally re-engineered the whole thing so that never, ever in its life can this GTR ever make another flywheel rattle noise. From that point of view it behaves like a normal car.
The noise you hear is the engine/turbos as it doesnt have an exhaust on in the video, its straight out the dump pipes :)
Just wouldn't be a GT-R without the rattles :P
this is interesting - how does the flywheel become 'loose' & why?
assuming the flywheel bolts run straight into the rear of the crank like a conventional engine - are the actual bolts under engineered or not correctly torqued from factory?
i'd stop at full bolts on and mod'd stock turbos, and spend the rest on a set of A005's for the stock 20's for such events
pretty sure Martin and Seb have run A005s iirc - Martin could you get away with A005s on rear wheels only and stock bridgestones up front?
Edited by domino_z
Arent they slicks? If they are they are not allowed. There must be a perfect combination of power vs traction for this type of event. Road surface will obviously be a variable factor. It would seem that Martins WR600 was better suited than Seb's setup.
Edited by g35me
Temora was all about traction over time.
Sebs Alpha 12 was easily faster than the WR600 through the acceleration increments once it had achieved full traction, however finding that traction balance was difficult on the day. It didnt help that Sebs car was running Dunlop road tyres where the WR600 was using the SportMaxx version (as a test, which worked well)
Towards the end of the day when Seb really got into the car it was indeed faster in elapsed time than the WR600 head to head however the track had gone off to the point where no more fast times were run. On a dragstrip it would have been a very different story - as you might expect.
Temora is no real test of car performance rather the ability to adapt to the surface.
 Share
