Both items are in as new condition and in perfect working order. I had a lot of plans for the steering wheel and as much as it saddens me to get rid of it other priorities have come up. I am selling the tablet because I don't use it as often as I like. Willing to post at buyers expense, item location is in northern suburbs Melbourne. Contact me via PM or call/msg me on 0402545233, if I don't pick up please leave a message and I will get back to you :)
Fanatec Porsche 911 GT2 Steering Wheel
Quick rundown of the wheel:
  • Compatible to Forza MotorSport (Xbox 360), GT5 (PS3), iRacing (PC) and all the other great racing sims
  • Alcantara leather rim just like in the original Porsche GT2 (100% identical material)
  • Smooth belt drive for sensational force feedback effects
  • Multiple adjustment possibilities with the TUNING functions
  • Force Feedback racing wheel with belt drive
  • ClubSport shifter paddles aluminum
  • Adapter cable to connect Logitech G25 /G27 pedals
  • Quick guide
  • Power supply
It is compatible with pretty much all the platforms (Xbox, PS3, PC). It comes with the wireless dongle for PS3 and I also have the adapter so you can use different pedals (e.g. Logitech G25/27). It comes with two different shifters, one is the sequnetial (up+down) and the other is 6 speed H-Pattern.Please note this is only the steering wheel, pedals do not come with it.
More info can be found here http://www.fanatec.d...eafdf440f927a15
Price: $230
post-44935-0-04078300-1342940608_thumb.jpgpost-44935-0-24501100-1342940589_thumb.jpgpost-44935-0-42981300-1342940599_thumb.jpg
Medion Lifetab P9514
This tablet would have to be one of the best bang for your buck tablets on the market. It comes with pretty much everything you need. Cameras, 3G + WiFi, very quick and responsive, rarely if ever crashes on me and it has really good battery life!
  • Just recently upgraded the firmware to Android 4.0.3.
  • 32GB memory
  • 3G + WiFi - holds regular sim card.
  • Front and back camera.
  • Long battery life - really it is, I am amazed how long this thing lasts for.
Full specs can be found here: http://www.pcworld.i...14/410218/specs
post-44935-0-52295900-1342940615_thumb.jpgpost-44935-0-95916400-1342940640_thumb.jpgpost-44935-0-69591600-1342940652_thumb.jpgpost-44935-0-12080500-1342940663_thumb.jpg
Price: $350
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
