All,
Does anyone have any test data (aero mainly) relating to the rear diffuser on a R34 GTR V Spec? Obveriously it does assist in some way (Nissan would not of manufactured a carbon sheet for nothing - I don't think!), but at what speeds and how?
Has anyone ever driven without their rear diffuser and noticed any differences?
Wondering if it is worthwhile removing as even though its carbon - it does add to the weight of the car and may not assist on the type of tracks I drive on (opposed to others - ie Nurburgring (High speed track)
Thanks guys!
I've driven mine without the diffuser previously, didnt notice any difference.
I actually have access to a replacement genuine Nissan rear carbon diffuser, still in excellent condition, if anybody is keen - shoot me a PM with an offer.
All,
Thanks guys!
Rear diffuser is for aero dynamic purposes as it keeps air flowing smoothly under the car.
You'd would probably only notice it on a track, (down the straights) going speeds above 100km/h or while you are speeding up on to an on ramp to a free / highway.
Z tune doesn't have one fitted.....
Because of rear diff oil coolers :D
Did the UK spec cars still have them fitted from factory?
I believe rear diff oil coolers are a R34 GTR Nismo Z-Tune item only.
But there is no stopping owners from putting a rear diff oil cooler on, a non Nismo Z-Tune.
I have seen some custom ones where they made NACA style ducts for the diff and transmission coolers.
Pics?
Pics?
The uk delivered cars definatly had additional coolers at the rear. I'm unsure if these were the same as the ones fitted to the the Z-tune (doubt it)
I'll have a search after i finsih work and see what i come up with regarding the diffuser
Edited by wedge_r34gtr
keen to hear if anyone has any data on this. I have fitted V spec diffusers to my non v spec 34 to improve high speed stabilty and reduce drag. I have significantly improved lap times with them fitted but hard to isolate the aero effect as i have made other mods and gained experience aswell.
Yeah sure, thanks :)
I do know the UK models did come with a few extras here and there but didn't know about the rear diff oil coolers.
But will be interested to know.
Couldn't find the thread that detailed the custom diffuser (pretty sure it was for a big $$$ build on SAU too :unsure: )
but the uk cars deffinatly had a transmission and a diff cooler mounted under the the diffuser. If you have a copy of the skyline story, you can see em when they put the uk car on the hoist.
I did note that the standard r34 diffuser has a duct to cool the rear diff...didn't really think of it till i saw a pic...so it wouldn't be that difficult to duplicate on a custom one to feed air to an oil cooler.
just of note aswell, one of the additional features listed about the Z-tune is "Z-Tune Dry Carbon Diffuser with 2.2 times more downforce than normal GTR ". Not sure if this is refering to the front diffuser, as i couldn't find any clear pics of a confirmed Z-tune that had a rear diffuser.
Ah yeah, found it on Wiki:
"The V-Spec version was also imported into the UK with a number of modifications carried out on the car. These included 3 additional oil coolers..."
But thanks :)
Would be the front as the is no rear diffuser on the Z-Tune.
i put one on my previous GT-T and there is an easily noticeable difference at high speeds. Cruising around, nothing, but at 80-100km/hr+ you could definitely feel the car was more stable. Even my gf sitting in the passenger seat noticed it and she a) didn't know it was on b) i hadn't even told her i put it on. Maybe it's a bigger difference to a lighter GT-T, but you could definitely tell the difference.
there are naca ducts in the standard diffusers.
as for the Z-Tune diffuser having 2.2 times more downforce..... that's relating to the front :) - diffusers can be front and rear. The front Z-Tune diffuser is mix of CF and magnesium... looks sex, can't buy em though unless you're a Z-Tune owner (or know one i guess) - hate to think how much they are...
Maybe we should try and organise a Tech Night on wind tunnel testing, -ve pressure below underbody diffusers, rear wing blade settings, height of stems, canards, NACA ducts, scoops and cd/wind resistance
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
    • Would be interesting what the price would be without the barracuda wheels. Looks like he dropped it down to 40k. Maybe his mate wasn't correct about the 50k evaluation. Has always been a dream of mine to own an auto 33. Looks like I'll have to keep saving my pocket money or ask mum for more pocket money.
    • Thinking about importing a stagea as a family car since i’m getting married this year, thoughts? Me and my fiance both like stageas, but don’t have any experience with them
