Hey Guys
Just some stuff I need to clear from the garage
located in Sydney
pick up preferred
S15
- Standard Coilpacks - $200
- Standard BOV - $30
- Standard S15 Wheels With used KU36 Semis and minor Rash- $500
- Standard S15 airbox No Snorkle $100
- standard JDM ecu $150
- Standard Air Vents x 3 $50 Each
- Apexi Power FC no hand controller - $650
- S14 Tailshaft - $50
- Standard Sr Exhaust Manifold - $50
- Brand new GReddy LS spec intercooler for s15. Unused and still in box. $700 ono
- s15 rear bar in black with a few small scratches and dings. $50
- driver side tail light (altezza - half red and half clear). $50 not neg.
- set of altezza tail lights (3 circles). $100 ono
- brand new alpine type S sub. still sealed in packaging. $100 not neg.
- HKS s15 intake system (arm, pod and clamps) - $150
R34
- Standard NISMO Sports exhaust R34GTT Catback. good condition no holes, no scratches - $300
- 3inch High Flow racing Cat - $150
- Standard R34 GTT alloy Wheels with tread but need replacing - $350
- Stock BOV - $50
Other
Turbosmart Megasonic BOV. good condition less then a year old - $220 (rrp $323 from www.forcedinductions.com/Blowoff.htm)
Exhaust cannon Carbon Fibre Tip
2 1/2 inch Inlet 3.5inch Outlet With Silencer $50
T28 Turbo inlet Snout $50
t28 actuator - $50
T28 Dump Only Split pipe- $100
Photos available on request
most of the prices are firm
please pm :)
Edited by rhino34
https://www.sau.com.au/forums/topic/405320-s15-and-r34-parts-random-parts-syd/
Cells, what cells.. Lol its a "super hi flow" ;) it came with the exhaust i bought from one of the member inferno something... i believe its a catco...
http://justjap.com/store/product.php?productid=18168&cat=275&page=1
i cant send u a mms of it if u pm ur digits :)
  • 1 month later...
Updated list.. Make offer guys :D
R34
- Genuine NISMO Sports exhaust R34GTT cat & Catback. good condition no holes, no scratches - $300
- 3inch stainless steel Decat (believe to be catco) - $50
- Stock BOV - $50
S15
- standard s15 radiator $50
- Zenon lights + balasts one with high/low in.same.globe $50
Random
standard EPA approved Cat (r33)
t28 actuator - $50
  • 1 month later...
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
