Depends on what you're after....
Response or Outright power/number? For me, Im after response. In saying that, I would go the 264° / 9mm option.
What head are you using out of curiosity? RB26? What turbos etc.?
All of the above makes a big difference when selecting a suitable camshaft.
Edited by R32Abuser
Yep it's a recently recod rb26 head with mild porting on in/ex. Has CP rb30det specific pistons in it giving a CR of about 9:1.
Like you I am after more mid range response then all out power. Just trying to find out what would be more beneficial to the 30 bottom end, either more duration with the HKS items, or less duration and more lift with the tomei?
I have been told the tomei type B's are a good all rounder, so leaning that way.
Cheers.
What will you be reving it to and how much of a power band do you need, mine runs to 7200 and has a good torquey power band from just over 4000 all the way to 7200, my inlet side is standard but my exhaust side has a bit more lift
From my googling and shop talk you dont want to go to big with the 30 as it is limited with its lower RPM.
Good point you make mlr. Yeah I probably won't be venturing past 7000rpm. Maybe I should just keep what's in there, it has camtech at the moment but I have nfi what thspecs. I might take another look at the rb30 power thread and see what people are doing on stockers.
What would be your recommendation Dan? You must have seen a few of these came through your workshop by now.
Well going off the size, that turbo is just bigger than a Z and just smaller than a GT4094 so you would be expecting somewhere about 500hp on 20psi before 7000rpm.
I would be going with a 260-270 deg advertised cam but pick something that has a 230-240 deg @ 50 as the faster ramp rate should give you better response.
a 260 won't fall over til around 8000 I don't think so it should be bang on the mark for what you want.
I don't know iff your head is assembled yet but one thing with RB TC heads is that they have a little less than an ideal ratio of valve sizes as in the exhaust is a little small but not by much . Slightly oversized exhaust valves can go in with refinished exhaust valve seats and a little throat blending .
The std size works ok on a standard engine but ones with better breathing really like this mod . The old SK R33 and mine really like this mod and appear to lose nothing anywhere - on both std and 256 8.5 Tomeis . The CR is up a littke at ~ 9.3 .
You can achieve the same thing with a bit more exhaust cam but mild valve train geometry is probably more reliable long term .
I reckon if anything is slightly lacking anywhere the bigger cylinders will make it more obvious - show it up sooner rev wise .
Food for though , cheers A .
Turbo is a borg warner S366 with .91 A/R on a lowmount HKS manifold.
Sounds good... do you mind posting some photos showing how the S366 will fit on the low mount HKS manifold? I am using a S366 too on my new engine!
I would give all the information on the engine and head to someone like Kelford so they can grind some cams for you to your application. If you had to choose between the two you already have go with the one with higher lift.
Yeah I just finished building the motor just recently, still only has 500k's on it. I regret not doing a little bit more head work now, ie exhaust side before it went on. I might contemplate it later on down the track.
Here are some pics for you Mike, don't mind the shitty welds it's pretty back yard spec.
I do love the s366 but, sounds like a 51r when it spools awesome turbo's for the price.
Cheers.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
