For Sale:
Nissan Stagea C34
RS Four S Dayz Edition
Driveline:
5 Speed Manual
AWD
2.5L Single Turbo
HPI Front Mount Intercooler
Apexi Pod (also have standard airbox and apexi airbox filter)
Apexi Turbo Timer
Apexi stainless steel turbo back exhaust system
Moongoose car alarm and Immobiliser
HKS Boost Gauge
Suspension
GTR Shocks with Stagea Springs
Whiteline adjustable Sway Bars
18" Blest Bahnsport Mags
Rides well, and handles great.
Exterior:
Excellent condition except for a few minor bodykit scuffs
Pearl White
Dolphin bodykit
Very tidy, straight panels
Interior:
Excellent condition
Dayz Edition
Dark Window tint
Reclining rear seats
Touch Screen Climate control
Android media player connected to stock screen (usb hard drive port in glove box)
Reversing camera - factory optioned
Cargo Net
Cargo Cover
Genuine Stagea floor mats
Genuine Stagea plastic boot liner
Motorised boot shut
12v power in boot (factory)
Headlights
Factory Xenon (HID) Headlights
HID High Beams
Always run on Premium fuel.
Oil and filter changed every 5,000. Fully Synthetic oil.
Gearbox, transfer case and Both diff oils changed at 120,000 with full synthetic.
Timing belt replaced with Genuine Nissan parts.
Car is kept garaged and always cleaned well.
Odometer: 160,000 kms
$12,000 ONO.
Contact Scott
0422 722595
[email protected]
Edited by scooter_r33
https://www.sau.com.au/forums/topic/405347-c34-stagea-rs-four-s-series-2/
  • 3 weeks later...
  • 3 months later...
Nice Ride!!! Is it sold?
How does the android media player work on the stock screen?
Do you use a mouse? Or a touch screen overlay?
Does it work while you are in drive? I would like to set it up. I have hooked into the inputs in the rear of the. Currently playing audio only off my galaxy s2, I wanted to make carputer out of an old lappie with an RCA out.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
