V Series Ebay Finds
Took the idea from the stagea section, tho some things are compatible with the V series i thought i would start one for the V series section, ive found some really cool rare things for the V series that ive wanted to share. Ebay.com.au/ebay.com/import monster/nengune.....share away
  • Replies 53
That thing is porn! If only I wasn't so in love with my steering wheel stereo and cruise control switches I would buy it.
I know right, i dont have cruise or audio controls so it doesnt bother me. But i dont have $500+
My nismo cluster looks different to that. It has mph on it also. That wheel is killa too. I have a factory momo wheel but again it's different as well.
Yeah i thougt it looked like and evo wheel too, thats the third style of momo wheel ive seen for the V series.
Would kill for the blinker wing mirror covers that ive seen on some sedans and on stageas
or these
19" Buddy Club P1 Racing II Plus Wheels
http://bit.ly/NUSgrf
or these
Lenso 19" Inch wheels & tyres, multi stud 5x114 & 5x100 suit Nissan, Subaru, etc
http://bit.ly/O67D3T
plenty to be found, all have gutter marks from poor driving skills
im still trying to find just ONE 20x10 or wider for a project...
Edited by Deep Dish V35
It is concerning how often some people gutter their rims.. had my J30 Maxima for 13 years, never touched the rims on anything.. even my wife has never damaged the rims on our J31 Maxima, and she isn't really a car person.
^^^ depends if you run decent offset and have stretched tyres or not. Many people (including me) love to have a wide rim and the stretched look (235's on my 9" rims and 265's on my 10" rims), so you have no bubble of rubber to protect your rim. One touch of a roundabout or kerb and I mark my rims in a major way. But it's the price you pay for looks :)
True I guess.. a downside if you are into the stretched look... I prefer the look of the tyres sitting flush with the rim, and most tyres do have a lip to prevent damage with a minor gutter/kurb touch.
I used to run 225s on the 9" rim on the front, but have changed to 235s now - not a massive amount of stretch, but the tyres offer the rims NO protection. Also, I use my car for work, so I park on the kerb literally 20+ times a day at different places, usually in a hurry, often with a laptop, tablet or phone in use - hence I catch a lot of kerbs!
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
