Dude you don't have to break the pump to spin a bearing. They have oil control issues from factory which causes bearings to spin. Plus its an old engine with god knows how many km. Factory didn't do too well in that area.
Im pretty sure a RB26 lasting 20 years
with god knows how much abuse it has received and the unknown km it has traveled, including all the launches it must have done, and red line pulls,
Is pretty damn good.
I know mate, that's why I said it depends which one he has. Do you think it's worth the trouble to change the oil pump on its own? All that work! If it's the late model one just leave it, even if it's the early model pump Its not worth all the work and trouble unless doing other things too.
I completely agree. No point changing oil pump until the engine is on its last legs. unless you're cashed up.
I was only emphasising "Factory didnt do well"
Lol sorry man I didn't express myself correctly, I know what you mean. I wasn't trying to say they were shit like I came across. I agree with you!
Regardless of your future plans for the car and If it is dead stock try these two and see how you get on.
Do a hot oil filter change.
Do an air filter element change.
Reckon then your first items would be a filter relocation kit and pods.
Lol, Have done it twice now, all you need is skill
IMO changing the oil pump is not justified cost/benefit wise, since, as stated, its an engine out job. Just don't hit the limiter and replace the harmonic balancer if its stuffed. I'd be more inclined to change the turbos, but then again, my oil pump hasn't failed and my turbos have...
Other than that just the normal stuff, so fluids, cam belt (and the associated idler and tensioner) if its anywhere near due (or if you dont know).
Those of us who drive completely stock 32 GTR's (not 33 or 34) would know the hydraulic HICAS valve bank makes changing the oil filter a mission. Filter can't be seen from above or below.
It also requires an AFM and boost pipework to be removed just to check an air filter.
I'll always put ease of maintenance ahead of modifications.
Obviously the FIRST thing any new owner should do is get the workshop manual and start reading.
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
