Dude you don't have to break the pump to spin a bearing. They have oil control issues from factory which causes bearings to spin. Plus its an old engine with god knows how many km. Factory didn't do too well in that area.
Im pretty sure a RB26 lasting 20 years
with god knows how much abuse it has received and the unknown km it has traveled, including all the launches it must have done, and red line pulls,
Is pretty damn good.
I know mate, that's why I said it depends which one he has. Do you think it's worth the trouble to change the oil pump on its own? All that work! If it's the late model one just leave it, even if it's the early model pump Its not worth all the work and trouble unless doing other things too.
I completely agree. No point changing oil pump until the engine is on its last legs. unless you're cashed up.
I was only emphasising "Factory didnt do well"
Lol sorry man I didn't express myself correctly, I know what you mean. I wasn't trying to say they were shit like I came across. I agree with you!
Regardless of your future plans for the car and If it is dead stock try these two and see how you get on.
Do a hot oil filter change.
Do an air filter element change.
Reckon then your first items would be a filter relocation kit and pods.
Lol, Have done it twice now, all you need is skill
IMO changing the oil pump is not justified cost/benefit wise, since, as stated, its an engine out job. Just don't hit the limiter and replace the harmonic balancer if its stuffed. I'd be more inclined to change the turbos, but then again, my oil pump hasn't failed and my turbos have...
Other than that just the normal stuff, so fluids, cam belt (and the associated idler and tensioner) if its anywhere near due (or if you dont know).
Those of us who drive completely stock 32 GTR's (not 33 or 34) would know the hydraulic HICAS valve bank makes changing the oil filter a mission. Filter can't be seen from above or below.
It also requires an AFM and boost pipework to be removed just to check an air filter.
I'll always put ease of maintenance ahead of modifications.
Obviously the FIRST thing any new owner should do is get the workshop manual and start reading.
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
