yeah, they've changed the way you search for outlets, pretty shitty change...
NSW seems to be
Rozelle
Dee Why
Drummoyne
East Blaxland
Conversely, just had another look at Melbourne outlets... got a stack more! :D :D :D :D
im from northern suburbs melbourne
closest to me is united in doreen
ive called up 4 times to united headoffice acting as a qualified tuner that i require e85 at mahoneys rd Reservoir and they said that location is on there " to do list"
my cuz has e85 on -7s (standard 26) made 379 on chequereds dyno and what a difference to my -7 setup it just revs so friggen harder
i told united headoffice, obviously its not a money maker in doreen because you have no hoons up that way, bring it to thommo and you'll see the line up (would look mint actually seeing all performance cars for the one bouzer)
dw about caltex thats pox rubbish
pull ya finger out united :D
official word from Caltex as far as i know... we'll all know in a couple weeks when i or someone else with a sensor tries a tank :)
would be great to let us know on feedback and even a PM to myself as im waiting on doing the e85 setup, but i want it as local as possible
  • 3 weeks later...
interesting list... who gave you that?
what car do you have? GTR or rb25?
1200 is overkill i would think, but not sure of your setup
Driftsales
http://www.facebook....06731592759916/
R33 gtst RB25
GCG higflow, apexi power fc, fmic, splitfires, "walbro was rated for 350hp or 255L"
When tuned putting down 222 - 236 rwkw @15psi
Edited by jukic.j
afm, probably (i maxed out around 250rwkw mark on my GT-T)
walbro might do you (i had drop-in walbro handle 280-290rwkw on my GT-T) - if not, get the new walbro one that is more suited to E85, has a '400' in model name i think.
injectors are overkill, and get the bosch style ones. If you're not planning on up'ing your turbo, some 725cc sized ones will be fine (injectors online for injectors, local place for us)
Fuel filter thing? haven't heard of that and i haven't run one in either my cars on E85
fuel lines??? wtf? that really sounds like someone who doesn't know what they're talking about.... they're fine.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
