My super drager was buggered in the cannon, all rusted and crumpled some how.. Causing a restriction enough to hold back a 12psi actuator to 8.5psi. Cut it open cleaned it out so its hollow but its very droney now lol :down:
Edited by GotsWapan
I've got a hks super drager on my 32 and it isn't loud at all. I may go down the path of removing the mid muffler to a resonator to get Abit more sound out of it.
Thought long and hard about doing this to mine as well.. but it is nice not being stung every time I get to take it for a drive.
LOL
Not only chicks,
I like to hear my turbo and whether the engine is pinging.
Also it is nice to listen to the radio.
A noisy exhaust doesn't cut it .. nor does a dump-valve ;)
The chicks love the quiet exhausts. Then they think they can talk the whole time ur driving
Edited by Torques
  • 3 weeks later...
Just to recap on the topic
I installed the exhaust and it is quite loud :(
There's a heavy low rpm drone which is more behind the car than in the car.
I got a lot of angry looks from people at bus-stations (if you know what I mean)
It's a bit much for city driving, and I will try to get the drone down with one of these mini silencers.
I suspect the exhaust is so noisy since I have no CAT installed ...
Its noisy cause there practically no muffler, a rear cannon like that will do nothing if its straight thru.. its not much different to having just a straight thru pipe on the end...
I used to have the exact same on the back, now i got a proper muffler and still make the power and it actually sounds alot nicer..
Which muffler did you get?
I found this one ...
http://www.japspeed.co.uk/Nissan-Skyline-R32-R33-Silenced-Decat/p-0-275/
Maybe worth a try (I'd get it cheaper)
a cat and a middle resonator/small sized muffler will help out a lot.
i cant say if that one will help much, i would guess it wouldnt cause it looks smallish...
I have a 3 1/2inch system with hotdog resonator and a 3inch X force muffler ( large oval) , the muffler is semi straight thru and forces the exhaust into it to muffle the noise , but obviously its flowing great cause it made well over 300kw..
I think you would be happy with a similar setup, it has a nice muffled , tough note thats quiet enough to hear your radio without dronning. can hear it in my thread on the dyno...
on my GTT i had a Hypergear OP6 Highflow and a R33 Super Dragger :), R34 is slightly shorter, so it only needed a little modifications. Mine was very quiet, running a CAT obviously (you're stupid not to) and i THINK there was maybe another section in there that's different to yours.
when idling i'd get people asking me if my car was on :D - but had a nice note, didn't drone and flowed well enough for the situation.
Thanks,
I removed the CAT 3 years ago, it's common practice here since (older) JDMs can get away with it.
(Removing that CAT actually made a big difference, so why is that stupid?)
Also my car was tested for emissions recently and it was all to plan, no complaints.
However I am considering getting a high cell count CAT.
I am certain that would also solve the noise issue ..
Edited by Torques
must of had a silencer somwhere.. cannons will never be quiet.. not like that..
put a high cell cat and you'll take some edge of it, better off with a 100cell cat or no cat, and a good sized oval proper muffler, semi straight thru
Hi,
What small box do you mean?
Do you have any pictures?
Suprised, seeing the pic.. as the one im about to put up for sale has a small box.....
And it wasnt to loud or drowny at all.
actually sounded good!!
Yep, I agree a 100%, cannons will always be on the louder side.
(especially when they are 3.5'' in diameter)
As for the CAT if I could find one with a 3'' flange that would be great.
The standard CAT is just 60mm (3''=76.2mm)
Edited by Torques
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
