My super drager was buggered in the cannon, all rusted and crumpled some how.. Causing a restriction enough to hold back a 12psi actuator to 8.5psi. Cut it open cleaned it out so its hollow but its very droney now lol :down:
Edited by GotsWapan
I've got a hks super drager on my 32 and it isn't loud at all. I may go down the path of removing the mid muffler to a resonator to get Abit more sound out of it.
Thought long and hard about doing this to mine as well.. but it is nice not being stung every time I get to take it for a drive.
LOL
Not only chicks,
I like to hear my turbo and whether the engine is pinging.
Also it is nice to listen to the radio.
A noisy exhaust doesn't cut it .. nor does a dump-valve ;)
The chicks love the quiet exhausts. Then they think they can talk the whole time ur driving
Edited by Torques
  • 3 weeks later...
Just to recap on the topic
I installed the exhaust and it is quite loud :(
There's a heavy low rpm drone which is more behind the car than in the car.
I got a lot of angry looks from people at bus-stations (if you know what I mean)
It's a bit much for city driving, and I will try to get the drone down with one of these mini silencers.
I suspect the exhaust is so noisy since I have no CAT installed ...
Its noisy cause there practically no muffler, a rear cannon like that will do nothing if its straight thru.. its not much different to having just a straight thru pipe on the end...
I used to have the exact same on the back, now i got a proper muffler and still make the power and it actually sounds alot nicer..
Which muffler did you get?
I found this one ...
http://www.japspeed.co.uk/Nissan-Skyline-R32-R33-Silenced-Decat/p-0-275/
Maybe worth a try (I'd get it cheaper)
a cat and a middle resonator/small sized muffler will help out a lot.
i cant say if that one will help much, i would guess it wouldnt cause it looks smallish...
I have a 3 1/2inch system with hotdog resonator and a 3inch X force muffler ( large oval) , the muffler is semi straight thru and forces the exhaust into it to muffle the noise , but obviously its flowing great cause it made well over 300kw..
I think you would be happy with a similar setup, it has a nice muffled , tough note thats quiet enough to hear your radio without dronning. can hear it in my thread on the dyno...
on my GTT i had a Hypergear OP6 Highflow and a R33 Super Dragger :), R34 is slightly shorter, so it only needed a little modifications. Mine was very quiet, running a CAT obviously (you're stupid not to) and i THINK there was maybe another section in there that's different to yours.
when idling i'd get people asking me if my car was on :D - but had a nice note, didn't drone and flowed well enough for the situation.
Thanks,
I removed the CAT 3 years ago, it's common practice here since (older) JDMs can get away with it.
(Removing that CAT actually made a big difference, so why is that stupid?)
Also my car was tested for emissions recently and it was all to plan, no complaints.
However I am considering getting a high cell count CAT.
I am certain that would also solve the noise issue ..
Edited by Torques
must of had a silencer somwhere.. cannons will never be quiet.. not like that..
put a high cell cat and you'll take some edge of it, better off with a 100cell cat or no cat, and a good sized oval proper muffler, semi straight thru
Hi,
What small box do you mean?
Do you have any pictures?
Suprised, seeing the pic.. as the one im about to put up for sale has a small box.....
And it wasnt to loud or drowny at all.
actually sounded good!!
Yep, I agree a 100%, cannons will always be on the louder side.
(especially when they are 3.5'' in diameter)
As for the CAT if I could find one with a 3'' flange that would be great.
The standard CAT is just 60mm (3''=76.2mm)
Edited by Torques
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
