Almost a complete package,
I can supply the front 6piston calipers not pictured for and extra $2500 for someone who wants the complete kit.
at a total of $5500 making it the cheapest V8 supercar kit i have seen up for sale.
(the 6 piston calipers will come direct from the race team to you)
Rotors are brand new: 375mm x 35mm fronts.
343mm x 32mm Rear.
Alcon Monobloc rear racing caliper: Body size is, 195mm wide by 255mm long. (the 6 piston is 200.5mm x 300mm)
Piston size's are, 31.8/41.3mm.
Pad shape, Pagid 1619.
Price:$3000 Firm.
I can have caliper brackets hats machined to suit any car but that will incur extra cost's.
PM, Txt or phone 0431 113 255 for any questions.
Located in Western Australia but can post at competitive rates.
Here are some photos:
and my last caliper bracket:
Thanks for looking.
https://www.sau.com.au/forums/topic/405426-alcon-v8-supercar-part-package-3000/
No catch, if anyone has issues with my low post count and no trading history your welcome to review my user on supraforums, i am a well established user on there and antilag. Package was for my supra but ive changed direction, this is advertised on all other forums so i imagine it wont be around for long, stuff like this at this price never usually reaches the forums.
What car/team are the fronts coming from??
I've been looking for a set recently and none of the guys I deal with have anything decent.....
Every supercar Alcon Ive seen has had a different bridge and pad retainer Inc the calipers I pulled of an ex GRM chassis just this afternoon Those look alot like ex Indy/champ car calipers?
http://www.skylinesaustralia.com/forums/topic/404689-massive-4-piston-monobloc-race-calipers/page__fromsearch__1
Aren't they "prototype" lemans calipers?
Stickers peeling up seem to indicate they are the same calipers advertised before....
Well if you read the title you may notice the word "part package" and as for the fronts, you obviously dont know the right people, you do realise that they are getting rid of alcon as the supplier because ap racing won the bid.
As for the caliper being a Daytona prototype, yes its from a 2010 riley daytona prototype, much better caliper than the rear that they use in the V8's similar design, pistons are slightly larger and so is the body size, the v8 alcon has stainless steel pistons and a solid bridge.
I dont just live in the world of V8 supercars, i have engineers in lemans teams over in the US and Germany.
The reason i am including the v8 caliper in as a kit because its a good match with the rear that is in the kit, i can get any other 6 piston caliper.
Go worry about other stuff if you not interested, but thanks for the free bump.
I wast aware GRM, techno, 888 and pmm were the wrong people to talk too.
I was actually interested in them and my question about where the fronts were coming from was serious. due to the component change over I know alot of places selling off rubbish that's been tarted up over the years.
I wast aware GRM, techno, 888 and pmm were the wrong people to talk too, I was actually interested in them
"Interested" You sound like the biggest time waster of them all, as for knowing all those teams if you where in the "know" then why dont you have a kit already seeings as you get 1st hand on every caliper there, and as for flogged out calipers, here's one going atm, so much for seasoned old tarted up stuff.
Brand new not even been used at a fraction of the price.
I think you are barking up the wrong tree, risking probably has a list of customers wanting any good used stuff that he can get his hands on, which explains why he is the only person on here that was interested
I have actualy had quite a few enquires and risking wasn't one, im not fussed if someone wants it they will buy it. maybe viewers are waiting for that "price drop" post, i can asure that wont happen, i would rather keep it than sell for less.
Edited by 24jzgte
Several customers, I have a prioritized list infact of people asking for parts.
Fasttrack are looking for taxi calipers and rotors for some new cars they are building. I had these
in mind for them.
Marshal (one of the owners) would tell me to buy every caliper I possibly can that's serviceable.
I have a car from every stable mentioned other than tekno so why wouldn't I be incontact with
said places regularly....
If your offering those Alcon calipers pictured new, and rotors like you advertised I'll take everything you have and I'll update some of the cars from AP's to these.
No I didn't.
I dont get alot of demand for ex Indy stuff and one of my suppliers came through with a heap of good AP & Alcon touring car gear so I bought all that up instead.
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
