Hi people stripping a tommi kaira editon r33 which is factory fitted with recaro seats , nismo wheels, nismo body accessories and a few other bits and pecies.
Engine and drive train wont be getting stripped until 5/8/12 as im moving sheds and need to transport car to my shed.
Contact me for anything else you need not on the list:
Recaro Sr3 good conditon no tears or major wear come with rails $1100
Nismo wheels 17s will have to check offest when i take them off come with good tyres $1350
5 stud converion kit front and back $660
Manual conversion kit with box $1700
Rb25det Tommi kaira motor Stock with ecu and harness $1700
Front mout kit $ 250
Rear diff $220
Rear Shafts $85 each
Bonnet $250
Nismo Grill $220
Sideskirts $150
Rear bar $150
Driver side guard $120 passanger $60 has big scratch
Door trims $75 each with speakers
Complete boot trim in good conditon $100
Carpet $50
3 inch mild steel exhaust turbo back $280
Radiator with shroud $175
More to be listed soon contact me if you need anything else
0402555849
Exhaust sold sorry
More prices:
Front control arms lower $55 each
Upper $50 each
Caster brackets $ 45 each
Front caster arms $35 each
Stock shocks and lowered springs set of 4 $120
Rear lower control arms $55 each
Camber arms $44 each
Rear Sub frame $160
hicas rack $88
Fuel tank $165
tail lights $ 65 each
Boot garnish $55
Rear seats good conditon $65
front crossmember $85
Power steer high pressurelines $45
stock turbo r33 $220
Carpet $35
Genuine floor mat set $45
Scuff plates $20 each
Kick panels $20 each
Ac condensor $75
ac lines $55
rb25det gearbox with new shifter bush $1350 or can be sold as conversion kit
$1700 for motor complete or $1200 long motor
Window regs $ 85 each
Door glass $65 each
Door handles $25 each
Rear quarter glass $65 each
heater core $85
blower motor $55
Ac core $55
Ac unit $45
Cluster surround $65
power window switch driver $75
passanger $45
Mirrors $45 each
mirror switch $30
Door lock set and ignition barrell with keys $100
Indicator stalks $20 each
rear uppers $25
rear lower trims $40
front pillar trims $25 each
front seat belts $55 each
rears 35 each
Boot battery fuse box $55
rear wiper motor $55
Front wiper motor $35
Dash pad $80
tommi kiara steering wheel has wear marks $80
gfb tee boost controller $40
Rear view mirror $35
dome light $25\
areial $45
boot realease cable $40
bonnet release cable $40
accelerator cable $40
Bonnet latch $25
abs sensors front $50 each
rear $60
sway bars $35 each
brake master cylinder $50
booster $35
front wiring harness $150
interior harness $80
Door skins $55 each
fuel pump $25
boot seal $ 20
boot hinges with struts $30 each
bonnet hinges $20 each
radiator support 250
o2 sensor $40
standard jack $25
fuel flap $15
rear shafts $65 each
rear diff $200
5 stud conversion kit
Starter motor $100
Front wipers $20 each
Whiper plastic trim $30
rear window lower trim $25
Anything else just ask
0402555849
Located newcastle but can post australia wide
post-90277-0-48990700-1343920833_thumb.jpgpost-90277-0-42952700-1343920852_thumb.jpgpost-90277-0-32687100-1343920870_thumb.jpgpost-90277-0-69491300-1343920888_thumb.jpgpost-90277-0-54029800-1343920979_thumb.jpgpost-90277-0-59869500-1343920998_thumb.jpgpost-90277-0-41598000-1343921015_thumb.jpgpost-90277-0-97063000-1343921031_thumb.jpgpost-90277-0-12750100-1343921113_thumb.jpgpost-90277-0-60909400-1343921129_thumb.jpgpost-90277-0-27763000-1343921148_thumb.jpgpost-90277-0-65787800-1343921166_thumb.jpgpost-90277-0-29794300-1343921185_thumb.jpgpost-90277-0-23829800-1343921203_thumb.jpgpost-90277-0-89172200-1343921222_thumb.jpgpost-90277-0-27149200-1343921241_thumb.jpgpost-90277-0-39269800-1343921264_thumb.jpgpost-90277-0-36906900-1343921282_thumb.jpg
Edited by runkos
Motor sold
Bonnet, grill driver guard, washer bottle, coolant overflow,drivers guard liner , sideskirts, intercooler sold
I also have a rb25det gearbox which has noisy 1st gear , needs shifter bush and had some metal on drain plug.
Test drove and it selects all gears and drove fine $850
Weather shields? Is there a matching pair?
Price?
Yep matching pair $55 plus postage
how much for lowered springs posted to melbourne mate?
Did you want shocks as well or just springs? post code?
hey mate do you still have the FMIC kit?
Fmic is on hold at moment .He has til Saturday to pay
Mint calipers no fading $ 275 front $165 rear or can be sold as conversion with discs hubs etc
Rear Bar $165
Trust style front bar damaged $ 150
Rear reo mint $110
Power steer reservoir $40
Charcoal can great for clearing defects $35
Boot trim complete set with clips includes boot lid trim $120
post-90277-0-65412200-1344429226_thumb.jpgpost-90277-0-42429700-1344429247_thumb.jpgpost-90277-0-54297500-1344429267_thumb.jpgpost-90277-0-99913500-1344429290_thumb.jpgpost-90277-0-37828100-1344429318_thumb.jpgpost-90277-0-92239700-1344429351_thumb.jpgpost-90277-0-51235200-1344429373_thumb.jpgpost-90277-0-99884700-1344429429_thumb.jpgpost-90277-0-99884700-1344429429_thumb.jpgpost-90277-0-57083300-1344429460_thumb.jpg
just the springs please mate postcode 3915.
Ill get onto it tomorrow mate
Do you still have the drivers side power window switches and has it got 11 pins ?
Yes still have switch . Ill double check pins tomorrow but im 99% sure its 11 pin
Few more pics from today plus a couple of new parts
Nismo strut brace with brake master cylinder stopper $180
post-90277-0-93971000-1344519195_thumb.jpgpost-90277-0-75401100-1344519274_thumb.jpgpost-90277-0-26444200-1344519298_thumb.jpg
Monkey rear wing on boot lid. $220
Door trims in good conditon $55 each
Mint dash pad no marks or holes $80
Cluster manual 139000kms $110
Dash plastic painted tommi kiara green/blue $35
Centre console in good conditon lid not broken $45
Spare space saver $ 55
Mirrors $45 each both have scraches but no cracks
Glove box assembly in good condition $ 40
Soniq head unit with remote and wiring $ 30
Stock intercooler pipe $25
Stock intercooler brackets $25
Areial $ 45
Passanger door skin has dent as market $ 35
post-90277-0-77258500-1344519339_thumb.jpgpost-90277-0-36541000-1344519363_thumb.jpgpost-90277-0-29347700-1344519386_thumb.jpgpost-90277-0-03414800-1344519434_thumb.jpgpost-90277-0-74712500-1344519455_thumb.jpgpost-90277-0-92270200-1344519744_thumb.jpgpost-90277-0-72109600-1344519770_thumb.jpgpost-90277-0-56217900-1344519794_thumb.jpgpost-90277-0-18334800-1344519837_thumb.jpgpost-90277-0-18334800-1344519837_thumb.jpgpost-90277-0-18798000-1344519860_thumb.jpgpost-90277-0-58880200-1344519916_thumb.jpgpost-90277-0-52365800-1344519955_thumb.jpg
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
