Item: Nissan Skyline R32 (RB20DET) Intake Manifold
Features:
- Give your engine bay a new look; top mirrror FINISH!
- 20% larger than the standard manifold allowing for increased air flow to each cylinder bank
- Plenum is designed to allow for precise air separation and allocation to each of the six original runners
- Complements performance cams, larger fuel injectors, fuel pumps and other such modifications
- Increases performance at med-high RPM range
- Made of precision aluminium - Alloy
- Ultra light construction
- Will accept original RB20DET throttle body (65mm version only)
- Comes with in-built bracket and port's to accept all original sensors, also incl. ALL 4x fittings (professional installation recommended)
- Upgrade to our universal 70mm throttle body, not a bolt-on
Now a new plenum for the RB20 guys as well!
INSTALL VID W/ SOUND HERE --- http://s623.beta.photobucket.com/user/wGNight/media/enginestart_zps912b2e0f.mp4.html
$295 including Delivery & Insurance - SAU MEMBER PRICE
Condition: Brand New
Contact: 0401599023 (anytime) OR info@vulturemotorsport.com
  • Like 1
Hi,
No modifications are required with our one, the only thing required is 1/8 NPT fitting for the vacuum port.
No installation instructions are supplied so professional installation recommended.
- Brendan
  • 4 months later...
  • 3 weeks later...
required
just bought this exact plenum, I am happy with it, its perfect for my specific needs, but you do get what you pay for, so cheap, is not without modifications, but easy mods,
I just ask that you guys describe your product a bit better
you don't need just one hose fitting, you need 4, as only one fitting from the original plenum will fit in the one big threaded hole, (thats the one on the underside) (just) it goes in about 4 turns) the other 3 do not accept anything from the o.g plenum, the holes are the wrong size, and the threads tapped arent the best, also some drill hole dags need to be cleaned off
  • 3 weeks later...
  • 2 months later...
  • 3 months later...
Big thanks to luke (calsonic14u) and brendan from vulture motorsport just fitted up the plenum and was stuck on the fittings but after a few quick calls we figured it out pretty fast we ended up using a 1/4 fitting barb to suit 5/8th hose and 3 1/8th fittings for the vac lines. Fired up first go :-)
  • 5 months later...
Sorry car hasnt had a chance and ive had no money to dyno her yet lol.
Oh and just for others info, just the wiring for the sensors on the throttle body need to be extended off the original harness. Very basic auto elec knowledge needed. And your Standard throttle cable of your R32 with reach no dramas. Some vacuum lines may need extending to.
  • 3 months later...
  • 2 months later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
