The guys at cv performance recommend me saving for a vipertech ecu and 650cc injectors. told me not to get anything less than that.
Edited by BOOSTBIG
a vipec is a better ECU no doubt, but if you are going for a highflowed turbo you aren't going to need anything more than a pfc / nistune
you will also need a z32 afm, 555cc injectors (minimum) aftermarket fuel pump, FMIC, better clutch etc etc
best search around here before you buy stuff.... have you already paid for the turbo?
the turbo you chose will influence everything else you need
damn :( the turbo is alread payed for and installed.
already have a fmic, exhaust, pod filter.
damn I thought the garret internals would put out decent power. I was going to upgrade to a bigger turbo in a couple of months though. just wanted something with a decent kick untill I go all out on a high mount kit.
what do you recommend?
depends on what you want to do with the car.
a highflow will get 300rwkw TOPS and that's pushing it. (i beleive hypergear have managed the 3 ton but generally highflows are 260-270rwkw
having said that have you driven a 3oorwkw R33? it's FAST
looking for more power than that out of a 2.5l will only lose response, and response where it's at (in my opinion)
i'd rather have a 250rwkw Rb25 than a 400rwkw RB25 anyday
your awesome man cheers. great great advice! I know where I stand now :)
nope never driven a 300kw r33 but I have driven a vl turbo 270kw on the weekend and it was scary fast. thing was spinning the wheels right up to 4th gear on boost. was hard as hell to control!
Hey man Im in a similiar situation too you, replaced my stock turbo as it was on the way out and the replacement now causes my stock AFM to max out so I need nistune and AFM too, I don't know where your located but I looked up a guy named toshi on the forums who can do a nistune for you for a fair bit cheaper then most places, pretty sure he's in Sydney maybe get in contact with him for your tuning? I plan too when I have the coin
Thanks heaps man. I'm located in dolls point sydney. so expensive for a ecu and tune though...wow!
I spent so much money rebuilding the damn thing now I'm hit up for another couple of g's :( it never ends
should be worth it though. I'f I get done I'll let you know how I go :)
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
