Statuatory Warranty Question
agentx
 Share
Hi guy - got a question about my other car ...
I bought a 2005 Mazda sp23 from a car dealer a week and a half ago. Went for a test drive and was all good except a slight ticking sound from the engine. Dealer said its been sitting there for 2 weeks so it might be lifters etc (I now know that the sp23 doesnt even have lifters).
Anyway long story short, the sound got really bad once the engine was completely warmed up, so I called the dealer who asked me to take it to "his" mechanic shop. At the shop, they straight away said its the bottom end and advised me to leave the car there and talk to the dealer.
Now his mechanic said its the big end bearing and he'll fix it in a day or two ... my question is, the bearing is a pretty big fault and unless he machines the crank etc and does everything properly (which he won't since he's doing this in 2 days) - it'll be a bandaid fix at best.
What are my chances of getting my money back from the dealer? On page 14, it says I should be able to?
http://www.accc.gov.au/content/item.phtml?itemId=963175&nodeId=cbe0411ccf8d0b8fbf2bdbacea75046f&fn=Consumer%20guarantees%20a%20guide%20for%20consumers.pdf
Thanks for your help in advance! :(
it's less than 10 yo car and you are within the cooling off period.
technically you can get your money back.
No dealer is going to want to however....
Considering it the engine thrashed..I would be hitting him up for it.
yea but the issue is the big end bearing (which was the fault) usually is a symptom of a much bigger issue ... which is what they wouldn't have fixed. so its kind of a band aid solution :(
Cooling off period is waived when you take the car. If you have agreed to fix it then that's the agreement, if ther repair work is faulty then u can get it redone but you own the car now.
^^ Sorry to say but Mazda 3's don't actually have lifters (I'm not that much of an expert, just what i was told) ... could be something else more serious? :D
Edited by agentx
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
