R35 Gtr Envy Dyno Haltech Tune!
GT-R OZ
 Share
Anyone used these guys to tune their R35? Looks pretty impressive.
'Quote under video'
This Dead stock R35 GTR makes 296 kw standard, after install and tune of the Haltech Platinum Pro R35 ECU a whapping 376 kw was acheived with absolutely no other modifications. The dump pipes start to get a little restrictive not wanting to flow more than 16 psi without rolling over, but the turbosmart E boost street certainly helps! none the less we think 376 is more than plenty for a standard set up! if you are wondering what its all worth? E boost street boost controller $645 fitted, Haltch ECU $4500 fitted and tuned.
Edited by GT-R OZ
That is a very impressive gain on a 100% stock car. 5k+ is a lot of coin so let's look at the options available
From a cost pov, with 5k you could buy yourself a Cobb access port, an exhaust including downpipes if you know where to shop, even an intake, and get same gain with a canned tune
From a features vs cost pov, you are far better off with a syvecs ecu - check out Martins running thread for his WR600, being able to set boost off the line for eg
Edited by domino_z
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
