Anyone used these guys to tune their R35? Looks pretty impressive.
'Quote under video'
This Dead stock R35 GTR makes 296 kw standard, after install and tune of the Haltech Platinum Pro R35 ECU a whapping 376 kw was acheived with absolutely no other modifications. The dump pipes start to get a little restrictive not wanting to flow more than 16 psi without rolling over, but the turbosmart E boost street certainly helps! none the less we think 376 is more than plenty for a standard set up! if you are wondering what its all worth? E boost street boost controller $645 fitted, Haltch ECU $4500 fitted and tuned.
Edited by GT-R OZ
https://www.sau.com.au/forums/topic/405480-r35-gtr-envy-dyno-haltech-tune/
That is a very impressive gain on a 100% stock car. 5k+ is a lot of coin so let's look at the options available
From a cost pov, with 5k you could buy yourself a Cobb access port, an exhaust including downpipes if you know where to shop, even an intake, and get same gain with a canned tune
From a features vs cost pov, you are far better off with a syvecs ecu - check out Martins running thread for his WR600, being able to set boost off the line for eg
Edited by domino_z
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
