my gf has a 34 coupe non turbo and im thinkin bout gettin some second hand parts to turbo it. just gonna run it on 5psi. Has anyone done it on here?? the plan is to source stock parts for as cheap as possible or some of them free (most of which u guys may just have lying around that u could donate to get them out of ur shed so u dont trip over them nemore ;) the parts im planning on using are
R33 turbo and manifold.
R34 stock exhaust system
R33 or 34 stock intercooler and piping
R34 AFM
R34 stock injectors
R33 or R34 ECU (1998 model) (im not sure if i can use a 33 ecu, does anyone know if it will plug in n work?
R34 oil/ water lines.
the car is a 98 model with tiptronic auto (separate transmission ecu) so im guessing im gonna need either a 98 r34 ecu coz the 99 model auto ecu has the transmission ecu inbuilt or a manual ecu. but my brother has a 33 so may see if his ecu will work?
also does anyone know whats involved with fitting the oil/water lines? is it pretty straight forward or do i need to tap into waterever water lines i can.
and where can i pickup the oil feed from? and do i need to drill into the block for the oil drain line?
if anyone has any of these parts lying around and wants to sell them to me or possibly give them away lol let me no.
https://www.sau.com.au/forums/topic/405484-r34-gt-gt-t/
Quite a few guys on here have done it... Get a total cost before you start buying parts to make sure it's worth doing, depending on the actual car it's probably quicker and easier to sell the GT and buy a GTT....
https://www.sau.com.au/forums/topic/405484-r34-gt-gt-t/#findComment-6457837
OP, I suggest you go and look in the Naturally Aspirated section. There is a thread in there called "How to Turbo Your NA" and it's full of priceless info on what's required, what to expect, results, etc. etc. It's your best source of info.
https://www.sau.com.au/forums/topic/405484-r34-gt-gt-t/#findComment-6457942
$$$ i have a de+T neo sitting here. The motor looks to be sold so i will be taking the turbo setup off it.
It has exactly what ur after, r33 turbo etc etc.
U will need an adjustable ecu of some sort, i recommend a NIStune
https://www.sau.com.au/forums/topic/405484-r34-gt-gt-t/#findComment-6458053
Yep.
And with that, closed.
https://www.sau.com.au/forums/topic/405484-r34-gt-gt-t/#findComment-6458056
Guest
    • bump. Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles. I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching. Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
    • If anyone has any suggestions for a 300-350mm long (or thereabouts) muffler that is 3inch in and out I'm listening
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
