so im looking at buying a set of these achilles 123 semi's. as there a street tire i dont think there really a real semi slick but thats what they call them. so im wondering if anyone has used them and can tell what there like in the dry and wet. there pretty cheap around $220 each. trying to compare them to the rsr and ku36 with a better tread wear.
Dunno about the semi sliks but my mate just replaced a set of Achillies road tyres on his wifes commodore that did less that 5,000kms before they were rooted... I think they are a pretty cheap shitty brand.
I was looking at trying them too... Most I've asked said they are on par with the other two choices... There are drift cars and track cars using them successfully, they are a street tyre like the others and should be fine.... As for the commo wearing them in 5000km, well it's a commo.... :P
I don't know their semi slick at all, but for a cheap tyre I was very impressed with their street tyre's grip. The extra wear Chris was seeing might be related to being softer/better grip than the usual chinese rock-hard tyre that lasts for 1billion klm but has no grip.
Nope, they will be along the lines of the KU36 and RS-R, a real grippy tyre for street.... I assume these will suck in the wet too.... My KU36 have done over 5000kms and are only wearing due to no wheel alignment since suspension work, they have a similar tread wear to the 123s I believe
Don't be fooled into getting these tyres, I have these horseshit tyres on the R33 I just bought, the rears are 275 wide and the car is stock, and I have crap all grip.
I ran smaller 255 KU31s on my old 240rwkW R33 and it provided more grip.
not to mention I have a friend with a mirage using the same tyres and he lights up 3rd gear with ease, well he is running an EVO 5 motor but that's not the point lol
Edited by johnnilicte
And yet SimonS14 and a couple of the other drift guys all rave about their grip?
it's like someone saying Linglong tyres provide hectic grip, try them out for yourself LOL... yashimash!
Are you sure you didnt use the achilles atr sport? because Ive also used the 123 and they are on par with the rsr in terms of grip.
Achilles 123 aren't sold in a 275 tyre as far as I'm aware also... :/
Danny Vahoumis drifts with the Achilles 123 also and it's apparently a pretty decent tyre.
I have 123s on my Evo 8 and I would recommend them to anyone. Great tyre for the price. In the dry they grip better than my toyo r1rs and federal 595 rsr. For the fella that spins 275s like the car is 500 horsepower... Your car suspension would be set up like a pile of sh*t.. That or you're driving in the wet clutch popping every two minutes.
Probably is too, just bought the car and it's running some rubbish pedders comfort shocks & springs, soon to be removed and put on eBay.
As for the clutch popping every two minutes, I'm not 18.
Can you confirm you're running 123's? What size are they if you are, cos you're not running 275's.
I'll look when I get home, they provide very bad lateral grip I can tell you! The car would come out around corners in a tight roundabout with some gas.
Could be a heap of reasons for that though!
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
