Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
made from a piece of aluminium I found in the scrap bin at a truck place.. :)
took 20 mins to make and its like 6mm thick too, so not going anywhere but meant I needed longer bolts...
Mine is the same, though 3.5mm from bunnings.
  • Replies 307
Posted Images
I'm actually surprised they OK'ed that without washers under the bolt head.
I'm just tossing up whether I should buy the 48's Traction have on special or just run the KU36's again, there might be another day left in them, I hope...
Mine are the same, Stainless M6 cap screws with nylock nuts, no washers on 3mm alloy strap. The scrutineers were wrapped with the install, compared to some of the other ones they had seen last Saturday.
Oh Martin, I knew someone would complain..where would you like to see washers mate, I'll put some there for you ok..I'd love to lend you entry fee too mate but I had to beg and plead with the finance dept myself.. I find the trick is to ask just before they're about to climax as they will enthusiasticaly say yes to anything ;)..Bar that Just sell a kidney or something you know it's worth it.
if my tax arrives might even enter!
I have a feeling you'll be receiving it soon :P
Care to post a pic of what your awesome one looks like? :D
Just filled out my Cams licence just then and was about to send, but then just realised I don't have a passport photo. Cot dayum...
Just used a facebook picture for the photo. Cams processed and should get it next week :D
Edited by blah_blah
I only fitted them on the drivers side for now, mainly because I don't sit in the passenger seat often. I tried out the bitch seat today and it definitely needs spacing up 10 or so mm at the front.
When I did mine the cams regs asked for body washers both sides and 2 x M6 bolts.
that said just glanced at the current regs and they have removed mounting info other that it must withstand 25G..no idea how scrutineers can test that!
So I withdraw my comment looks like it would pass current regs
There are no washer for the seat.....
1. You don't want the fire ext under the brake pedal!
Man there's no way that extinguisher is getting past my legs, even if it did its not going to fit under the pedal..
It can easily be mo ed to the passenger side anyway should officials complain :)
If it's flying around the cabinet at PI it could end up anywhere.
End of the day, it's common sense. No teck screws, bolts that are made from metal and not plastic (zipties) and attached in two locations so it doesn't swivel all over the place.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
