Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
lol it such a hack track compared to PI..
This is the bit I hear all about gets me worried...watch from 1 minute
that's Roy a SAU member.
he was leaking Gearbox oil I belive (could be engine)
so the rears were coated with oil when he went to turn in.
so assuming your not planning on pouring oil on tyres prior to going out you should be fine.
  • Replies 307
Posted Images
I went off turn one forgetting to brake lol
looks like i wont be partikipating here :( way too much needs to be done to get it on the track
allignment
touch up tune
tow
cams
membership renewal(will happen anyway)
but i doubt all will be done before the 11th lol
Edited by Sunkist
Scared bud?
Just get it all done, you will need it for the next track day. Why else are you powering the car up, you can't use it on the street...
Scared bud?
i am getting it all done. but traction tyres cant have me in till next week because i need to flare the guards some more.. and thats only if i have time then.
all happening. not as soon as i thought it would though.
Can we sign up for cams on the day or has to be done before hand...don't think there would be enough time for it to be processed by mail.
There is a tear off slip down the bottom of the application which you can use on the day.
An SAU VIC representative will have to sign it. As Richo won't be there I'm assuming Martin or myself can sign it?
Good to see another first timer will be out with me! :D
Or even an email. I sent mine in with an attached Facebook picture as the photo as I didn't have anything else lol
Was processed and sent out within a few hours :thumbsup:
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
