Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
  • Replies 307
Posted Images
Nah I have to pump the guards before I give the car to them. The only time I have is this weekend. So I'm hoping I can get it done. I'll be lifting the car for them too.. Dropping it to them isn't a worry
I don't know how much camber they will put it for a 'track setup' someone said they'll put quite abit in. But don't know if they were talking about fronts.. Eh I should be able to get another 3-4mm out of it. So with a but more height shod be fine
on the cams application form it has PO box 427
and under the contact us section on there site has PO box 147
any difference in the two? wanna send forms of today.
[email protected]
will solve all of your worries. and will receive the license much quicker.
Are you using a heatgun on the paint Aaron?
Yes you will need to for sure. Rob did his with a roller and gun, plus some scotch.
Athid is a sure bet though, will be done perfect.
yeah hes done a real clean job on your car John...what would be the charge to get all 4 done you think..
finally figured what is rubbing on my car and its not the wheels at all...its the dump slighty hitting underneath my car ....must rememebr to fix that
Couldnt have done it without the Scotch!
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
