Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
  • Replies 307
Posted Images
sounds like tampered, if you can can get into scruit under it's own power and not drop a couple litres of fluid, plus your helmet has a sticker you pass
Haha really? I heard some people at PI had cable tied their fire extinguisher in aswell
Me too, weight saving ftw. lol.
That is true :P
I've turn the boost down on my stock turbo to 9-10psi. So down to about 170-180rwkw.
So i'll be slowly going around the track whilst you zoom past me :P
Jam the GPS between the sun visor and roof. Phone goes in centre concole with helmet bag so it doesnt rattle around.
Camera mounts are somewhat of a farse. suction mounting is hit and miss with the officials.
So do we have a little area were we can put our tool kit, spare oil/coolant etc... that I want to bring just in case?
Do I just make sure I take it all out before it goes into scrutineering?
shove it in my car if you want. ill be driving there.
good to see more than 2 cars in the std awd class. hoping for a dry day though.
Fingers crossed. Would really like my first track day to be a dry one...
Weather at this stage doesn't appear to promising
hello to all,
introducing myself as a first time track day member. Looking forward to sandown this weekend. see you there!
Welcome!
I recall seeing your membership application come through :D
yeah weather not looking the best I have seen, but should make it more ....fun
oh well just so long as one dry session that enough.
oh for those of you that looking for a garage they can be pre-booked
ring Brendan on 0403189352 and give him the details of the day.
if you can get 3 of you together works well, as most are 3 bays so you can share with friends and put all your stuff under shelter.
when we were there earlier this year was $40 per garage.
I've booked 3 for me and my work mates.
Call today and ask to have one near mine if you want!
I'm interested Tony, and so is Artz i'm sure... You want to call or should I? :)
Yeah why not. $40 for 3 cars. $13.33 isn't going to break the bank
That way if my car breaks down you can help me fix it :D
You can call :)
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
