Sau Vic 2012 Motorsport Championship Round 5 - Sandown 11Th August
  • Replies 307
Posted Images
sounds like tampered, if you can can get into scruit under it's own power and not drop a couple litres of fluid, plus your helmet has a sticker you pass
Haha really? I heard some people at PI had cable tied their fire extinguisher in aswell
Me too, weight saving ftw. lol.
That is true :P
I've turn the boost down on my stock turbo to 9-10psi. So down to about 170-180rwkw.
So i'll be slowly going around the track whilst you zoom past me :P
Jam the GPS between the sun visor and roof. Phone goes in centre concole with helmet bag so it doesnt rattle around.
Camera mounts are somewhat of a farse. suction mounting is hit and miss with the officials.
So do we have a little area were we can put our tool kit, spare oil/coolant etc... that I want to bring just in case?
Do I just make sure I take it all out before it goes into scrutineering?
shove it in my car if you want. ill be driving there.
good to see more than 2 cars in the std awd class. hoping for a dry day though.
Fingers crossed. Would really like my first track day to be a dry one...
Weather at this stage doesn't appear to promising
hello to all,
introducing myself as a first time track day member. Looking forward to sandown this weekend. see you there!
Welcome!
I recall seeing your membership application come through :D
yeah weather not looking the best I have seen, but should make it more ....fun
oh well just so long as one dry session that enough.
oh for those of you that looking for a garage they can be pre-booked
ring Brendan on 0403189352 and give him the details of the day.
if you can get 3 of you together works well, as most are 3 bays so you can share with friends and put all your stuff under shelter.
when we were there earlier this year was $40 per garage.
I've booked 3 for me and my work mates.
Call today and ask to have one near mine if you want!
I'm interested Tony, and so is Artz i'm sure... You want to call or should I? :)
Yeah why not. $40 for 3 cars. $13.33 isn't going to break the bank
That way if my car breaks down you can help me fix it :D
You can call :)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
